Old 10-30-2020, 10:22 PM
BLG BLG is offline
Default Can't seem to open "cloud project" created with Pro Tools First with Pro Tools
I just bought the full version of Pro Tools after using First for a few months and I have three projects located "in the cloud". They show up in my list of projects but when I try to open one I get a box that says "Looking for new versions on cloud...". That just hangs (I've waited for for up to 10 minutes).
I've read about the preference to save locally and not the cloud, but I've been collaborating and needed the cloud.
I am able to open a different project though (although it's been downloading for close to 20 minutes and it's just half way through the 86 revisions). What's up with that? That never happened in First.
Old 10-30-2020, 11:14 PM
BLG BLG is offline
Default Re: Can't seem to open "cloud project" created with Pro Tools First with Pro Tools
I was eventually able to open the first project, but now there's another one that gives me a hard error. I get "There was a problem downloading "song name". I can still open it in First but not the full version of PT.
Old 11-02-2020, 06:39 AM
junkgear's Avatar
junkgear junkgear is online now
It's possible that something didn't sync correctly with that one project that will not open.
You can try opening it in First, making some small changes to the project, then saving it, which should force it to sync again.
With cloud sync, it is critical to make sure that projects have finished syncing before exiting PT or Windows for that matter.
You should always have the PT Task Manager window open (Window -> Task Manager) to make sure there are no running processes before closing PT.
As for the slow downloads, sometimes I think it's just Avid's servers being slow, but sometimes just logging out of your Avid account from within PT, then logging in again will for whatever reason speed things up.
Will
System Details
Old 07-31-2021, 08:43 PM
knowtice knowtice is offline
What would the fix be if it just doesn't get past the "Looking for new versions on cloud" pop up? I can't open anything I've saved on the cloud. Trash prefs?
Old 01-22-2022, 03:08 AM
CSP1978 CSP1978 is offline
I am having the same problem. I have 15 projects save to the cloud and now can’t open any of them.
Did you get a resolution to this
Old 01-22-2022, 10:14 AM
You might get faster help if you file a support case with Avid support. https://www.avid.com/learn-and-suppo...-music-support
Folks all over DUC have been reporting issues with this cloud mess for years, many folks here (including me) have been warning not to trust any work on this. You really need to get off First and/or Avid cloud.
Old 01-22-2022, 02:31 PM
jeffro's Avatar
jeffro jeffro is offline
Originally Posted by CSP1978 View Post
...I have 15 projects save to the cloud and now can’t open any of them...
Welcome to the community.
I see you started a support case for this so please watch for a case update email.
The projects are also on your drive as long as you don't manually Remove Local Cache... for them in Pro Tools' Dashboard.
Also, please back up (but don't delete or move) your Project Cache folder (HD/Users/*username*/Documents/Pro Tools/) and Project Locations folder (HD/Users/*username*/Library/Preferences/Avid/).
linkedin
Cloud Project Won't Open Due to Error "Could not create a new document because..." Joey_Sommers Pro Tools 2019 1 04-22-2020 08:49 AM
Project Versioning under the "CLOUD" rogerhavoc Pro Tools 2018 7 05-12-2016 01:24 PM
"Created with an older version of Pro Tools" j4callen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 04-13-2015 08:37 AM
Cannot open session in Mpowered7.3 (created in 7.3 but gives "older version" error) Krizaps Pro Tools M-Powered (Mac) 3 02-18-2011 12:31 AM
Can't open "session created on older version" - but it wasn't! BookSix Pro Tools TDM Systems (Mac) 9 02-04-2009 07:38 AM
