Time adjuster plug in won't bypass
Hi all,
I am doing some playing around with the Mellowmuse ATA delay comp plug. Anyway I threw a few time delay plugs onto a number of drum tracks in a mix to simulate some plug in latency and to try to get the ATA to fix it. While the ATA worked fine I noticed that the time adjuster plug in cannot be bypassed. Its delay effects are removed only when you make the plugin inactive. I would be interested if anyone else has seen this. Is this a bug? Cant see any other reason for it to happen. Cheers By the way I am using PT8 Last edited by bukman; 05-31-2009 at 04:42 AM. Reason: forgot to add spec |
Digi Time Adjuster bypass question | clausiii | Pro Tools M-Powered (Mac) | 12 | 10-29-2013 10:04 AM |
Time Adjuster plugin doesn't bypass correctly | Marco Migliari | Pro Tools TDM Systems (Mac) | 5 | 01-12-2010 06:34 PM |
BUG: Time Adjuster long- bypass doesn't work. | reichman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-22-2009 09:24 AM |
Time Adjuster bug: "bypass" doesn't seem to work | jmark | Pro Tools M-Powered (Mac) | 2 | 11-29-2006 10:45 AM |
Time adjuster plug in ??? | Jules | Pro Tools TDM Systems (Mac) | 4 | 03-08-2000 11:42 AM |
