Old 05-06-2004, 09:32 PM
jpoprock jpoprock is offline
Default Software that put\'s \"beep\'s\" in the song.
I'm looking for software that places "beeps" in the audio ever 10 seconds or so. I need to be able to let the customer to hear the product by leaving them a CD, but I want to make sure that the CD is unusable for any medium, but good enough sounding to "approve". Dig what I'm saying?
Thanks!
jason
Leo 10.5.7
PTLE 7.4.2, 002r, Micro
iMac G5 2.33ghz Core Duo Intel
OWC External FW HDD
http://www.soundclick.com/jasonsheroan
Old 05-06-2004, 10:04 PM
cybership cybership is offline
Default Re: Software that put\'s \"beep\'s\" in the song.
I think so. Another option might be to just slate the intro. Take # so & so , guitar eq down 2 db @ 250hz, blah blah blah.
Old 05-06-2004, 11:09 PM
Gunnar Hellquist Gunnar Hellquist is offline
Hmm.
You could probably do it using the things already there.
Make a short beep sound somehow. Perhaps using the click plugin. Pad it up to say ten seconds with silence and consolidate the region. Now you can make as many copies of this after each other as you want.
The quick fix is to simply include this in the mix. The beep will come on top of the other sounds.
The longer solution is to both use it in the mix and to have it in the side chain of a processor on the main mix, making the beep turn down the sound of the song to zero.
Well, sorry if my description is a bit unreadable.
Gunnar Hellquist
Gunnar Hellquist
true amateur
Old 05-06-2004, 11:26 PM
Use the signal generator, set to noise. Record a few seconds. Drop the region periodically on an empty audio track.
Or use the signal generator, and draw some mute animation.
Quad 2.5 G5, 4.5G RAM
Old 05-07-2004, 06:07 AM
Good ideas.
I was thinking about that sound generator and I also thought about using a trumpet stab via Reason or something. Recording one, then copying the region throughout the song.
Just thought I'd see if there was a utility that just DID IT. But I can do it this way easy.
Thanks guys!
Jason
Leo 10.5.7
OWC External FW HDD
Old 05-07-2004, 07:54 AM
Carl Z Carl Z is offline
Just be careful not to make it a discernable instrument.
C
"I'm one of the few people I know who knows the few people I know" - CL
Old 05-07-2004, 07:59 AM
sdelsolray sdelsolray is offline
Download the Altiverb reverb plugin demo. Use it on the master fader with the verb set to zero. It will bleep for you every 10 seconds or so.
Babylon - My first 11R song (and first 100% solo song I've ever done) Variable Eleven Rack 9 09-12-2011 08:14 PM
How to copy one song out of a multi song session? Kevin Mowry 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-14-2007 11:36 AM
Separating song tracks in one session -Software/PI highhopes19 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-14-2005 02:31 PM
Implement software update option into ProTools software Samhein Pro Tools TDM Systems (Mac) 1 07-09-2003 12:47 AM
ok.,,, my song is 5:25...but, I want the same song to be 5:15 -- how do I condense? MidiMidiBangBang 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 09-03-2001 12:14 AM
