Change audio engine on start up
Switched IO devices and I used to be able to "About a year ago" hold the "N" key during startup to change the audio engine. This no longer seems to work. I get a program time out 3 times then it says my audio engine is no longer there, erro -6117 and all I can do is quit protools.
I'm not sure what version I'm running other then 12.5, I am not in 12.7 Thanks, Jim |
Re: Change audio engine on start up
Weird.
Why not just change it in the setup menu drop down after PT launches? Sent from my iPhone using Tapatalk |
If holding down 'N' does not give you the option of an interface then the problem is likely with the driver/interface not Pro Tools. Try rebooting your computer, power cycling the interface, updating the driver, etc.
The 'classic' cause of this with Avid/Digidesign (and likely MAudio) interfaces is allowing the computer to sleep/suspend while the interface is connected. |
Because pro tools will not come up because I changed IO |
I ended up putting my old IO back in, pro tools came up I was able to switch in setup then all was okay. |
I'm not sure what version they started, but there have even more oddities with ASIO devices and changing I/O. It can be very annoying.
Can't Change Playback Engine | Jack Vandal | Windows | 15 | 01-08-2014 08:43 AM |
No m-audio interface in current engine (playback engine) | SlicerSounds | Windows | 1 | 10-04-2012 12:27 AM |
"Audio engine play start deadline was missed." Huh? | mixboy bob | Pro Tools TDM Systems (Mac) | 1 | 01-09-2009 11:56 AM |
Can we change the video engine rate? | mparsons99 | Post - Surround - Video | 0 | 02-14-2007 12:51 PM |
dae engine won't start | [email protected] | Digidesign Hardware & Software | 2 | 10-30-2000 06:26 PM |
