Old 12-24-2009, 03:59 AM
Martin Dubka Martin Dubka is offline
Default Can I monitor 2 inputs but only record 1 of them in LE?
Any ideas? I'm using a 003R.
Cheers,
Martin
Old 12-24-2009, 04:07 AM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Default Re: Can I monitor 2 inputs but only record 1 of them in LE?
Yes. Create one record (audio) track and one auxiliary track. Select the appropriate hardware inputs and solo-safe the aux track (cmd+click on S) and record enable the audio track.
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 12-24-2009, 04:24 AM
You can route hardware inputs to Auxiliary's?
I never noticed that...
Is it zero latency as with an audio track?
Old 12-24-2009, 06:39 AM
Latency will be the same(according to the buffer setting and a little for conversion).
Old 12-24-2009, 07:09 AM
flommer flommer is offline
I thought the HW buffer accommodated the conversion..
I guess it would be easy to test with a ping out and back in..
And to the OP, there is no such thing as zero latency with digital recording...
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 12-24-2009, 09:18 AM
So with "Low Latency Monitoring" selected, my audio track will be fine but my auxiliary will still be at the mercy of my hardware buffer?
Old 12-24-2009, 11:24 AM
The AUX track will be exactly the same as the audio track(assuming no plugins inserted).
Old 12-24-2009, 11:31 AM
Pedro perez Pedro perez is offline
i use this to feed reverb while tracking..cuz unles you run a mac-pro at least buffer size at 64(acceptable latency for most people ) it's just not doable
curious as to Why u wanna monitor 2 inputs and record only one.why not record both then just mute?
Old 12-25-2009, 10:37 AM
Exactly the same way you use them mate ;-)
I sometimes struggle with reverb sends while tracking vocals if the session is too big
Monitor DI Inputs w/o running PT on Mbox 2 Pro? plangentmusic Tips & Tricks 0 11-06-2010 07:29 PM
Why can't I monitor inputs during playback? danoan522 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-08-2010 12:33 PM
How To Monitor S/PDIF Inputs joseph halloran 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-01-2008 12:02 PM
can't monitor inputs ccguitar1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-09-2006 11:20 AM
monitor inputs to headphones janrudi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-29-2000 08:00 AM
