Old 03-23-2009, 05:54 PM
Intini Intini is offline
Default D-Command and D-Control: Controlling Sound Monitors
I am planing on buying a D-Command or a D-Control in the next months. I wonder if I should get a Crane Song Avocet to control my monitors now or I should just buy a SPL Volume 2 (or SPL 2Control) and then wait until I get the D-Command or D-Control and use it to control the monitors. By the way, I am assuming that both (Command and Control) have a monitor controller(?). Do they? Is it comparable to the Avocet (or Grace Design or Dangerous Music stuff)? If I am going to spend £2300 (pounds!) on the Avocet and then later the D-Control (or D-Command) has it all there may be no point!
Please, you out there with a D-Control or a D-Command, can you comment on your experience with monitor controlling?
Thank you so much!
P.S.: If you would like to make a one line comment on the C|24 monitor section that would be appreciated, as there is 1% of chance of getting it instead of the Icon.
Old 03-24-2009, 05:33 AM
Mikey MTC Mikey MTC is offline
Default Re: D-Command and D-Control: Controlling Sound Monitors
The monitoring path in the D-Command and D-Control is via the XMon which ships with it. It's a very full featured analog section which sounds very good.
While you might get marginally better audio performance with a Avocet or other device, the Xmon is beautifully integrated into the ICON environment.
I suppose this might depend if your motivation is some sort of convenience or feature set that the external controller has, or whether it's pure audio performance.
Old 03-24-2009, 05:15 PM
Thank you so much for your answer. I am interested in audio performance basically. I want the most transparent audio signal possible.
Old 03-25-2009, 04:09 AM
Will Russell's Avatar
Will Russell Will Russell is offline
I have no issues with the sound of the D-Command monitoring path. Like Mikey MTC said, it is very full featured and sounds very good.
Will Russell
Electric Wilburland Studio
www.wilburland.com
12 core 3.06Ghz MacPro, OS 10.14.5, PT2019.6, HDX, D-Command
Retina 5k iMac OS 10.14.5, PT2019.6, MBox3
Retina MacBook Pro OS 10.14.5, PT2019.6
Old 03-25-2009, 04:48 AM
There could be some argument for better audio performance but you would be getting down to the minutae. Seriously, the XMon is no slouch in this regard - a serious improvement on anything Digi's had before in previous work surfaces and right up there with the expensive dedicated systems.
Also, I couldn't imagine using a secondary monitoring solution with the D-Control. It would be a PITA to set up, you'd have to put it somewhere convenient which may not be possible, and after all that, you really may not gain anything.
Old 03-27-2009, 11:42 PM
dr sound's Avatar
dr sound dr sound is offline
Try This:
http://www.neyrinck.com/Pages/vmon.html
Marti D. Humphrey CAS
aka dr.sound
www.thedubstage.com
IMDB http://www.imdb.com/name/nm0401937/
Like everything in life, there are no guarantees just opportunities.
Controlling VSTi's with MC Control KeyplayerG Artist Series 0 02-20-2014 07:24 AM
Command 8 not controlling Pro Tools Tiki love god ProControl, Control|24, Command|8 2 01-23-2012 04:51 PM
MC Control not controlling RME totalmix johngar Artist Series 2 08-08-2011 07:13 AM
Controlling Monitors through Hardware? 11 Rack. chrissyb Eleven Rack 2 05-31-2011 12:38 PM
Controlling plugs with the Control 24 Nicolasixxx ICON & C|24 4 06-14-2005 01:06 PM
