Old 09-30-2005, 02:54 PM
hatterasgrey hatterasgrey is offline
Default Great.. Pro-Tools doesnt even playback....
I have a Digi 001 with Pro Tools 6.4 ....
AMD 64 Dual Core +3800
ASRock 939 Dual SATA
Windows XP Pro SP2...
Installed it, and as soon as it loaded up BLUESCREEN...
Fixed it by turning of the Data Execution Program thing in windows.
Now Pro-Tools runs, I can load tracks up...
One problem though,
When I try to playback or record I get errors -9093 and -9129...
I've adjusted the H/W Buffer sizes... it says to much, then to little
CPU Usage = 95%
DAE Buffer is at default.
Anyone have this problem or know how to fix it????
The Digi001 records just fine in Cubase
Thank you
Old 09-30-2005, 02:57 PM
spkguitar's Avatar
Default Re: Great.. Pro-Tools doesnt even playback....
Start with all of the steps in the General Troubleshooting thread.
Old 09-30-2005, 05:36 PM
I tried all of that in the guide.... and still the same thing... here's my system specs.
SiSoftware Sandra
System
Host Name : HATTERAS-2CBCE3
User : Administrator
Domain : HOME
Processor
Model : AMD Athlon(tm) 64 X2 Dual Core Processor 3800+
Speed : 2.00GHz
Model Number : 3800 (estimated)
Performance Rating : PR6000 (estimated)
Cores per Processor : 2 Unit(s)
Threads per Core : 1 Unit(s)
Type : Dual-Core
Internal Data Cache : 2x 64kB Synchronous, Write-Back, 2-way set, 64 byte line size
L2 On-board Cache : 2x 512kB ECC Synchronous, Write-Back, 16-way set, 64 byte line size
Mainboard
Bus(es) : AGP PCI PCIe USB i2c/SMBus
MP Support : 1 Processor(s)
MP APIC : No
System BIOS : American Megatrends Inc. 8.12
System : 939Dual-SATA2
Mainboard : 939Dual-SATA2
Total Memory : 1GB DDR-SDRAM
Chipset 1
Model : Acer Labs Incorporated (ALi) ??? (1695)
Front Side Bus Speed : 1x 200MHz (200MHz data rate)
Chipset 2
Model : Advanced Micro Devices (AMD) Athlon 64 / Opteron HyperTransport Technology Configuration
Front Side Bus Speed : 2x 800MHz (1600MHz data rate)
Memory Bus Speed : 2x 166MHz (332MHz data rate)
Video System
Monitor/Panel : ViewSonic VA702b
Adapter : RADEON 9800 PRO (Omega 2.6.71)
Adapter : RADEON 9800 PRO Secondary (Omega 2.6.71)
Physical Storage Devices
Hard Disk : Maxtor 6Y080P0 (76GB)
CD-ROM/DVD : PLEXTOR DVDR PX-740A (CD 48X Rd, 48X Wr) (DVD 6X Rd, 6X Wr)
CD-ROM/DVD : Generic DVD-ROM SCSI CdRom Device (CD 32X Rd) (DVD 4X Rd)
CD-ROM/DVD : SCSIVAX DVD/CD-ROM SCSI CdRom Device (CD 32X Rd) (DVD 4X Rd)
Logical Storage Devices
Hard Disk (C:) : 76GB (13GB, 17% Free Space) (NTFS)
(D:) : 540MB (CDFS)
CD-ROM/DVD (E:) : N/A
180MB (CDFS)
Peripherals
USB Controller/Hub : ALi PCI to USB Open Host Controller
USB Controller/Hub : Standard Enhanced PCI to USB Host Controller
USB Controller/Hub : USB Root Hub
Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
Mouse : Microsoft PS/2 Port Mouse (IntelliPoint)
MultiMedia Device(s)
Device : MPU-401 Compatible MIDI Device
Device : Digidesign Digi 001
Device : Realtek AC'97 Audio
Power Management
AC Line Status : On-Line
Operating System(s)
Windows System : Microsoft Windows XP/2002 Professional (Win32 x86) 5.01.2600 (Service Pack 2)
Network Services
Network Drivers Enabled : No
Performance Tips
Warning 100 : Large memory sizes should be made of Registered/Buffered memory.
Tip 2546 : Large memory modules should be ECC/Parity.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
Old 09-30-2005, 08:27 PM
JMS40 JMS40 is offline
Chipset 1
There's a problem.
Old 09-30-2005, 08:48 PM
BrianDiAngelo BrianDiAngelo is offline
Chipset 1
There's a problem.
What? Acer labs is a problem??? I have an Acer Aspire notebook! does that mean I'm in risk that the MBox 2 I ordered won't work on it??
EDIT: it HAS to work, right???
http://www.brianserge.com
feli
ponk es un cab
rón
Old 09-30-2005, 09:16 PM
The ALi chipset is unsupported.
Old 10-01-2005, 10:35 AM
I'm sure its not listed under the "supported" hardware section, but just because it isn't "supported" it should still work unless it's incomptaible like some of those intel chipsets. God forbid if I ever buy digidesign hardware again. What's funny is that my old 450mhz Gateway computer (from 1999) can load up Pro-Tools no problem, it's slow, but it still loads up records/plays. And this AMD 64 3800 (from 2005) doesn't work with it? thats a load of crap.
Old 10-01-2005, 10:44 AM
Chipset is a very important piece of the puzzle, and ALi chips have been problematic.
Old 10-01-2005, 10:45 AM
spkguitar's Avatar
Definitely not true.
Exactly.
Digidesign does not support the 001 anymore. That means that they don't test, qualify, or support the 001 with ANY new systems.
You are trying to use a top of the line cutting edge computer with hardware that they don't even support anymore. I would expect a number of incompatibilities and surprises.
Old 10-01-2005, 10:48 AM
Thanks for your help, it looks like I got screwed on this deal... Time to sell that piece of junk and get a FIREPOD .
CORRECTION: Adat Device doesnt playback audio during Recording or Playback DarylBham 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 07-21-2010 11:16 PM
Pro Tools doesnt launch on Mac Intel sucundum 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-02-2008 04:17 PM
Pro Tools doesnt start anymore - help please matic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-16-2008 09:36 AM
small playback problem. any help would be great. wreckthisplace 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-07-2005 04:24 PM
MOTU doesnt seems to like pro tools TDM... :) darenceang Pro Tools TDM Systems (Mac) 4 11-03-2005 01:33 PM
