  #21
Old 10-03-2011, 05:26 PM
Default Re: HD Native Upgrade or Downgrade?
Latency compensation for plugins works just as it does for every DAW on the planet. Everything gets delayed to match whatever track has the highest latency from plugins(assuming its within the 4096 samples that Pro Tools allows for). I am speaking of native here as I don't work on HD enough to know if they have a bigger range of compensation. For this reason, i tend to avoid any plugins on the master and leave ADC off until i finish tracking. As for master plugins, I tend to leave that as a separate process anyway(but will toss Waves L2 on the master for a quick reference bounce).
  #22
Old 10-03-2011, 07:32 PM
Pro Tools DSP based systems have a maximum delay compensation length of 4095 samples, Dave.
Aaron Mulqueen - 001 HD Native
  #23
Old 10-03-2011, 07:38 PM
Originally Posted by nst7 View Post
There's more to HD Native than meets the eye, because of how it's designed. http://www.avid.com/static/resources...ilyLatency.png
Thanks for posting that nst7. Yes, although Native card does not have the same round trip latency as DSP PCIe based systems. Native card does out perform FireWire and USB based systems due to how the Native cards onboard FPGA processing handles the I/O. Thus separating Native card from USB and FireWire based systems by a considerable amount.
  #24
Old 10-03-2011, 10:12 PM
BobbyDazzler's Avatar
BobbyDazzler BobbyDazzler is offline
Originally Posted by digidesigner View Post
Things like that make me sceptical of guys saying "i run gazillion plugins at the buffer of 32 without a hiccup!"
I can run 361 Dverbs on a 64 buffer (483 on 1024 buffer)
It really is plugin dependant though. Some plugs seem to be way more efficient with their code than others.
Having gone from TDM to RTAS, I still do the exact same amount of tracking through plugins that I used to do, (which is very little).
The biggest workflow change for me is keeping an eye on the buffer and CPU settings.
5,1 Mac Pro Dual Hex Westermere 3.6Ghz, 24gig Ram, Pro Tools HD Native 2018.4, Sierra, Blackmagic Decklink HD Extreme 3D.
  #25
Old 10-04-2011, 12:50 AM
digidesigner digidesigner is offline
Native processing for real time audio will probably be officially good when someone comes out with a live mixing console like Venue and proves it works reliably enough :)
One more thing I started thinking about HD Native and how "cheap" it will be in the end.. do you guys realize you will be buying a new computer every year as you are addicted to getting MORE cores and mhz :) Good old G5 would still be "doing the trick" if Apple didn't kill the OSX on it for most TDM users
  #26
Old 10-04-2011, 08:55 PM
do you guys [Native card users] realize you will be buying a new computer every year as you are addicted to getting MORE cores and mhz :)
Good old Mac user, never lifted the lid off his computer. PC users generally are savvy and update intermittently when component support is suitable. Upgrades however are rare but necessary once every three to four years due to the rapid nature of components no longer in circulation.
  #27
Old 10-05-2011, 03:59 PM
Hercules Hercules is offline
As long as you mean "PC replacement" when you say "upgrade" ;-). The leapfrog methodology is the lowest risk.
  #28
Old 10-06-2011, 11:23 AM
nerd513 nerd513 is offline
i already have
  #29
Old 10-06-2011, 11:31 AM
ejwells's Avatar
ejwells ejwells is offline
Originally Posted by nerd513 View Post
i already have
Oy (pt. II)
Pro Tools 10.3.3 | HD Native | HD I/O 8x8x8 | Mac Pro 8 Core Westmere | 24GB RAM | OSX Lion 10.7.4 | API 3124 | Chandler TG-2 | UA 4-710d | Empirical Labs Distressor EL8X | Kemper Rack |
  #30
Old 10-06-2011, 12:04 PM
Dism Dism is offline
Originally Posted by ejwells View Post
Oy (pt. II)
It did better in the box office, but doesn't quite compare to the original.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Downgrade Native firmware 10 to 9? Hugh-H Pro Tools HDX & HD Native Systems (Mac) 2 04-12-2013 09:53 AM
PT 9 HD to 10 downgrade? (native) brucecoughlin Pro Tools HDX & HD Native Systems (Mac) 3 11-27-2012 11:35 AM
DIGI, can I upgrade or "downgrade"? CharlesL 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-23-2006 10:13 AM
Quicktime Upgrade then Downgrade. Kitch Pro Tools TDM Systems (Mac) 0 05-02-2005 05:07 AM
