Punch In Recording Level Changes
I am recording in Pro tools 10 with a firewire 800 Apogee Duet and recording an acoustic guitar (one track DI and one track Mic) whenever I punch in the waveform and volume is much larger. I have talked to many persons including avid and they cannot fix the problem. It is on a Mac Book pro, no plug ins, very straight forward. When I do punch in I have to massively reduce the clip gain to match levels. No pre amp or input level raise between takes the volume and wave form simply go up with no reasoning at all. Don't pay attention to the plug ins on the photo those have been removed too-still happening for no reason.
Re: Punch In Recording Level Changes
This might sound too obvious but, are you sure you are at the same distance from the mic on every take?
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
How much are you having to reduce clip gain on the punches?
Just a thought, but are you playing along with the track before the punch in? Almost every musician and vocalist I've worked with tends to play louder when they are hearing playback and not themselves in the headphones. then when the punch in happens, the volume and energy of the performance doesn't match, with the punch in being louder.
Scott Gatteño |
Do you have separate playback and record faders setup?
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Recording level vs playback level.. | DigiDudeski | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 02-04-2009 05:00 AM |
Punch-in recording? | GloryIsSilent | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-17-2009 09:43 PM |
punch in recording | mastermorris | Tips & Tricks | 2 | 12-02-2005 02:23 PM |
Does anyone still use punch-in recording? | RobN | General Discussion | 7 | 07-16-2005 05:33 AM |
Punch in recording | d_matt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 06-08-2003 09:24 AM |
