Old 09-02-2006, 04:47 PM
jkw318 jkw318 is offline
Default Who can explain this?
I've been a mac / PT user for 5 or so years now. I had a iMac G4 with PT 6.x and it would randomly not let me monitor the output of PT or anything using Core Audio from neither the headphone jacks on my mbox nor the Line outputs.
I got a powerbook G4 and everything worked find. I just got a power mac G5 and core audio / PT has only properly worked 1 time.
My MBox is fine, it works everywhere else. Everything is set up correctly its not some little mistake.
I've talked to Digi and they cant help me past basic troubleshooting (unless i pay an arm and a leg i dont have to do their other tech support) I've talked to mac...same deal.
This is really annyoing because i bought this $1500 computer for PT and nothing works!
So heres the deal...in PT or Logic or iTunes w/e i'm using, It shows the audio meters just no output on any type of monitoring system i use.
I've tried a buch of different combos of the OS and PT version still nothing works!
HELLLLLP!!!!
Power Mac G5
PowerPC G5 (3.0)
CPU Speed: 2 GHz
Memory: 1.5 GB
Currently PT LE 7.1
Core Audio 7.1
Old 09-02-2006, 05:28 PM
yOkO yOkO is offline
Default Re: Who can explain this?
could it be a core audio compability thing ?
you should post secifical syst details so
people in here can help
so what
Old 09-03-2006, 01:29 AM
chris110000100101001 chris110000100101001 is offline
Possibly the mix knob is set to "input"?
SMPTE for the devil
Old 09-03-2006, 07:15 AM
no nothing like that at all.
Old 09-03-2006, 07:22 AM
Kryst Kryst is offline
I seem to recall somehow recreating something similar last night, but I can't remember exactly what I did... my thought is only on what those Sources are set on, in the front of the mbox. If you're plugged into the Inserts (TRS), the light should be on "mic". If you go through Source 1 (Mic (XLR)) with a 1/4" cord, you need to set Source 1's light onto Line, or Inst. For guitar at least, Line and Inst both seem to work fine IMO, but Inst comes out alot louder than Line. Also, if using a 1/4" cord through the Source 1, you do not need S/PDIF on.
Kryst
Old 09-03-2006, 08:08 AM
Thanks for your input but thats not the issus, it wont let me play any thing using Core Audio, whether it be a cd or something in PT
Old 09-03-2006, 12:07 PM
Reformat and do a clean reinstall of OS X and don't install anything except the Pro Tools application. (You can do this to a separate Hard Drive if you prefer... then boot off that drive).
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 09-03-2006, 12:21 PM
BRH BRH is offline
Why do you want to monitor PT through core audio? Monitor PT through you PT hardware.
Could someone explain me something about ADC please? mixaudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 10-21-2008 04:14 PM
Can Someone Explain This??? Tricky Sam Pro Tools M-Powered (Win) 1 08-25-2006 10:02 AM
Please Explain Pete Evick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-23-2003 01:33 PM
Somebody PLEASE explain why... silence_of_stone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 12-27-2002 07:54 PM
Explain it to me again... phdumas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 05-01-2002 06:55 PM
