Old 03-15-2016, 05:56 AM
Stuart@YM Stuart@YM is offline
Default Outputs configured in I/O setup not available to select as track sends/outputs
Hi all
I'm experiencing an issue whereby I/O settings are behaving strangely upon opening new sessions.
I created a new stereo Output called Ext Mixer (outputs 5-6) which, initially, are selectable as outputs or sends from audio tracks. So, all good.
However when I open a new session, the I/O doesn't change but the outputs/sends are no longer available from the audio track drop-down menus...
If I delete the I/O and start again, creating the outputs etc from scratch, they then become available again from the drop-down menus but doing that every time a new session is opened would be very inconvenient.
I have attached screenshots showing the I/O and the track dropdown menus.
Any suggestions v much appreciated.
Pro Tools HD 12.8.2
OSX Sierra 10.12.6
iMac 2017
16GB Ram
Radeon Pro 570 4096 MB
Avid S3
Old 03-15-2016, 06:23 AM
Benny_Cha_Cha Benny_Cha_Cha is offline
Default Re: Outputs configured in I/O setup not available to select as track sends/outputs
In the new session, in the bus window, is your bus actually assigned to the physical output?
Ben Rubin
Producer//Mixer//Bassist//Composer
benrubin.com
twitter // instagram // facebook // imdb
PT Ultimate 2018.7, Mac Pro 5,1 12-core 3.46, 24Gb RAM, Mac OSX 10.12.6fd, SSD boot drive, SSD sample drive,
Neve 8816, HD Native PCIe, Apogee DA-16X, Lynx Aurora 16, Benchmark DAC-1/ADC-1
Old 03-15-2016, 06:30 AM
Drew Mazurek's Avatar
I/O Setup, buss tab, click default.
www.drewmazurek.com
Old 03-15-2016, 07:59 AM
Benny - yes the bus is mapping to the physical output, thanks.
Drew - yes this made the output appear, thank you. I'm finding however that I need to Default (Output Busses) every time a new session is opened to make this one Output appear...any suggestions?
Pro Tools HD 12.8.2
OSX Sierra 10.12.6
iMac 2017
16GB Ram
Avid S3
Old 03-15-2016, 09:50 AM
Have you tried clicking on the box that says "show last saved setup"?
Ben Rubin
benrubin.com
Old 03-21-2016, 07:44 AM
Benny - It's greyed out, even when I default the output busses.
I have just been selecting "output busses" and clicking Default, which restores the outputs to the track dropdown menus, making them selectable.
It must be a bug of some sort. Thanks for the help anyway.
Pro Tools HD 12.8.2
OSX Sierra 10.12.6
iMac 2017
16GB Ram
Avid S3
Outputs vs Sends Jedisteph Avid Pro Mixing General Discussion 4 09-19-2015 12:56 AM
Can't Select Certain Inputs/Outputs 11HD Omni. Colin Gusto Music Pro Tools HDX & HD Native Systems (Mac) 7 07-17-2015 01:52 AM
sends vs outputs pinnacle Pro Tools 10 6 09-04-2012 05:36 AM
outputs vs sends for mixing down within pro tools roark 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-30-2011 03:59 PM
Sends Vs. Outputs 3Dbuddah Pro Tools TDM Systems (Mac) 0 06-21-2003 04:28 PM
