Old 07-19-2007, 02:55 PM
john1192 john1192 is offline
Default quad core macpro and le using all cores ?
does anyone run a system like this .. can you or Digi tell me if Pro Tools LE is using all the cores ... or ???
thank you
john
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD -OS 10.12.6 for PT 11.3.2 & 2019.6 last version
Logic Pro X latest version
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.14.6 - PT 2019.6 Ended here ..
RME BabyFace Pro
Old 07-19-2007, 03:12 PM
Tasters Tasters is offline
Default Re: quad core macpro and le using all cores ?
I had Heard that you would not be able to fully utilize all of the cores until Mac OSX Leopard and Pro Tools 7.4
Not sure if that was correct but was told that in March by a Digi employee
Old 07-19-2007, 04:07 PM
CME CME is offline
Someone posted pics of his rig doing I believe the DVerb test on his system. He got an amazing amount of plugs and according to activity monitor it was using most of all cores, and if I remember his was an octo-core system. Here is the thread where Bortraws posted the pics. So we may get better results with 10.5 but it's working pretty good as it is.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier.
Old 07-19-2007, 06:39 PM
Matt82au Matt82au is offline
i believe currently you can use all cores as lon as the buffer is at 512 or higher, otherwise you may get increased buffer underrun errors. It works great for me, currently track with 2 processors and 64 buffer, then mix down at 512 with all processors. Just keep that in mind and it will be fine
Matt Perrott
Sound Designer and Engineer
Sydney, Australia
Matt Perrott
Sydney, Australia
Old 07-26-2007, 04:16 PM
MindDead's Avatar
MindDead MindDead is offline
http://duc.digidesign.com/showflat.p...part=1#1180524
Old 07-26-2007, 04:39 PM
ennbr ennbr is offline
When I ran my tests after receiving my quad cord Mac Pro it was in fact using all four cores. It also was maxing out the 4 GB of memory installed in the system. The link below does not have pictures but does contain the results of my tests.
http://duc.digidesign.com/showflat.p...v=#Post1103353
Pro Tools 10 and quad cores algy Windows 9 02-16-2012 06:25 PM
MacPro Quad-Core 2.8 GHz enough for PT 9 ? cozy_man Pro Tools 9 1 01-27-2011 07:48 AM
2006 MacPro Quad Core 2.66ghz 16Gb ok for HD9? grills macOS 4 12-20-2010 08:22 PM
latest MacPro 12 cores support bobo mark Pro Tools TDM Systems (Mac) 0 09-18-2010 01:40 AM
Continuous random performance issues PTLE 8.0 MacPro quad core. Help! murph16 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-21-2009 08:44 PM
