Old 03-16-2006, 06:09 AM
digimike digimike is offline
Default CAN NOT FIND INSTRUMENT TRACK UNDER FILE NEW TRACK
I am using pro tools version 7 and when I choose file new track, I see the options for audio, midi, auxilary input, and master fader but none for instrument track. Any ideas why?
Old 03-16-2006, 06:24 AM
spkguitar's Avatar
Default Re: CAN NOT FIND INSTRUMENT TRACK UNDER FILE NEW T
No ideas. Never seen that happen before. Are you using a standard install (to the default location)? What other software do you have installed? Did you upgrade from a previous version to 7? Have you tried a re-install/repair?
Old 03-16-2006, 06:32 AM
YttriumMusic YttriumMusic is offline
Default Re: CAN NOT FIND INSTRUMENT TRACK UNDER FILE NEW TRACK
Are you sure this is PT 7? I thought in PT7, the new track option was no longer under the File menu, but under the Track menu. What is under your "Track" menu?
Old 03-16-2006, 06:40 AM
spkguitar's Avatar
Yes indeed. I totally glossed over that; if you're selecting new tracks from FILE menu, you're not using 7, or something went wrong with your install.
Old 03-16-2006, 04:22 PM
neatguys neatguys is offline
its at the end of the list
Davec 1 results,32+68 at 1024 buffer,32+ 41 at 128 buffer both 24 bit
import midi file for virtual instrument track butchhutch Pro Tools SE and Essential (Win) 0 08-25-2012 01:31 PM
Bounce Instrument Track to .wav File DJKeys macOS 2 06-05-2012 01:06 PM
sustaining one instrument track while the second track is not sustained with foot ped nrsjunkmail777 MIDI 0 09-28-2011 06:58 PM
Can't Mute or Change Volume on Audio Track and Instrument track FunkTools 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-10-2010 04:40 AM
Mono Instrument Track VS Stereo Instrument Track mbox2issue Tips & Tricks 8 04-20-2009 04:21 PM
