Old 04-06-2020, 11:15 AM
sw rec sw rec is offline
Default Re: protools 2020.03 AVID broke OMF import
Between that and beating my head against the wall trying to import video, I'm VERY tempted to roll back to 12.4 HD at this point. And my $1199 "reinstatement" was for........?
Old 04-06-2020, 11:42 AM
seanmccoy seanmccoy is offline
Is the OMF import bug happening on both Mac and Windows?
ADK Core i7 4.20, 32GB RAM, W10 Pro, PT HD 2020.9.1, HD Native, OMNI, Digi 192, AJA Kona LHi, UAD-2 Octo; Mac Pro 12-core 3.46, 64GB RAM, Mojave, Logic Pro 10.5.1, Apogee Rosetta 800, UAD-2 Quad, MOTU 2408 Mk II: MBP mid-2012, 16GB RAM, Mojave, MOTU 8-Pre-ES, Pro Tools 2019.10
Old 04-07-2020, 07:36 AM
grayter1 grayter1 is offline
Yes. It's happening on Windows too. I had 4 AAF's sent to me yesterday that were fine. I got several OMF shorts this morning and none of them will import.
tg
Win 10 Pro / i7-6700K 4.00GHz / GA-Z170X-UD5 / 32 GB / nVIDIA GTX 1050ti / RME BabyFace Pro FS / Yamaha MODX6 / Komplete S49 / Pro Tools Ultimate 2020.9 / Nuendo 10.3 / Reaper 6 / Studio One 5 / Komplete 12
Old 04-07-2020, 08:40 AM
gives's Avatar
gives gives is offline
Not sure if this will help, but I have used this to help Nuendo to import a proper OMF info that platform from Mac to PC. I works great and they offer a test for free thru the company to show you if it works prior to purchasing it.
From the old folks who brought you the Fairlight.
https://www.aatranslator.com.au
Maybe they have a solution for this problem, but at any rate it's work noting this solution here.
G
Gregory Ives, Composer/Sound Designer/Musician
http://www.gregives.com
https://pro-labs.imdb.com/name/nm1170521/?ref_=sch_int
Protools 2020.9 Ultimate HD Native Thunderbolt Avid HD IO
Mac Pro 3.5GHz 6-Core Intel Xeon E5 64GB of Ram
OSX Mojave 10.14.6, Digital Performer 9.5.2, Logic Pro X 10.5.1
Old 04-07-2020, 09:26 PM
NickFLZ NickFLZ is offline
Same issue here - PT Ultimate 2020.3 cannot import OMF files. I wish I had known that before I upgraded, ugh.
Today I've had to open any OMFs in Cubase, export as an AAF and then import that AAF into a protools session. What a pain.
Nick
Sound Design/VO
http://noisefreak.com
Old 04-08-2020, 07:03 AM
clusterer clusterer is offline
I´d just leave PT2019 and rename the app PT_OMF .. later on just install PT 2020 in the meantime... open OMF session with PT_OMF, save session and open with PT2020
G. Rasek - recording engineer - www.overdub.at - european VO talents via source-connect - PTHD
Old 04-08-2020, 07:23 AM
Suite Spot Suite Spot is offline
Just to set the record straight - I have met the guys from Fairlight (they are located on the coast and are very cool guys) and I'm at the base of the Blue Mountains and other than the fact we are Aussies that's about all we have in common ;-)
If you are using AATranslator then the best solution is to convert the OMF to AAF or PTX
AATranslator
Old 04-08-2020, 11:16 AM
gives's Avatar
Yeah Nick.. I hear ya.. I'm glad I waited.
Old 04-08-2020, 09:51 PM
pablovius pablovius is offline
same issue here.... OMF opened fine yesterday with 2019.12-- today cannot with 2020.3. Rolling back now... thumbs way, way down.
Old 04-10-2020, 08:48 AM
rmccam rmccam is offline
Hi Everyone,
I just thought to weigh in here because I'm opening OMFs on PT2020.3 on 10.15.3 Catalina on a new 2019 Mac Pro without any issues.
That said, it has to be an OMF with separate audio, not embedded, to work. Embedded OMFs will crash PT 99% of the time... however, this was an issue I'd had for probably the last 6 months, through at least 3 versions of PT.
I work with a lot of different editors, most of whom are working in Premier now, and after talking with many of them about it, I have a few running, albeit unproven, theories:
• There's something in the use of multiclips that causes issues, I think. I believe it's if the editor doesn't "flatten" them first.
• If the editorial team is accessing assets from a centralized server.
• If the editor is working on a PC vs a Mac.
• It's a bug in PT or in the export of the OMF itself.
Again, these are just educated guesses but the first one seems to fix many of the problems I run into.
All that said, as annoying as OMFs with separate audio are, I've been asking editors to send them for months now and I've never had a problem – and I work in commercials mainly these days, so I'm dealing with, probably, 4-10 a week.
Hope that helps.
Ryan
Ryan McCambridge
Producer • Sound Designer • Mixer
HTML code is On
New Avid Link 2020.1 - launched today 1/16/2020 marianna Licensing & Accounts 8 01-16-2020 11:43 PM
Avid drops Pro Tools reinstatement on 01-01-2020 Delta Music Belgium Licensing & Accounts 6 11-27-2019 03:19 PM
Avid announces Pro Tools 2020, 2021 and 2022! off the wall Pro Tools 2018 2 04-01-2019 08:50 AM
2018.7 Broke Hidden Tracks from Import Session Data moogboy100 macOS 0 11-01-2018 11:08 AM
Has Avid broke the DUC??? Keybeeetsss General Discussion 12 04-13-2010 12:14 PM
