Re: ProControl and G5 question
>so far the only thing it sees on stereo tracks, is the left pan<
You can switch between the left and right panners by pushing the "Pan" button to the left of the panners, above the "Input" button.
Mark Ettel C.A.S. |
Thank you for that!!!
Hassan. |
I got this communicationloss too eversince i switched to a G5.Before i worked on G4 with HD3 system also 3 faderpacks mainunit plus editpack
Hmmmm....Interesting. Propably this loss of communication is a G5 issue. Maybe there's a clue in getting hints from digidesign how to configure network settings? |
Just an update-
I have been running the G5 for the last 3 days and all I can say is WOW- I mean really WOW- As a torture test, I ran the following session- Now let me say up front, this session did not have any automation (since it was all stems). OK, I ran 40 tracks of 48k/24bit audio with a Quicktime movie from the same Firewire 400 drive- just to be greedy, I turned playhead scrolling on. Well- It all played. And the counters and meters behaved like a 1 track session on my G4 933 (single). Just for giggles- I turned on the Picon track (set to frames as opposed to blocks) this did cause some periodic lurching- however I think it was more to the drive being able to keep up- it was running with nearly no available seek time with this option running. my conclusion is that I should have went this way months ago- I bought a refurb dual 2.0 (wPCI-X) form Apple for 2099.00, I then put a 250 gig second drive in and another gig of ram- total cost for everything including monitor adaptors was under 2500.00 If you are on the fence, I would really recommend it- The responsiveness of the interface is an order of magnitude better compared to the G4 (even the dual 1.25's) Oh yes- It is the quietest mac I have ever owned- I actually am getting bothered by the noise my powerbook makes now... (except when using the DVD drive- that is still noisy) One downside- the thing requires a lot of AC power. thats it for today- charles maynes Quote:
charles maynes sound design and recording for film and media 818 618 0580 Member IATSE Local 700, MPSE, ATAS, NRA & USMCHC. |
ProControl and C24 Question | jcolagross | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-22-2011 06:48 AM |
Procontrol monitor question | rich morpurgo | ProControl, Control|24, Command|8 | 5 | 07-29-2005 06:12 AM |
Procontrol/hd 192 question *DELETED* | DREN STARR | ProControl, Control|24, Command|8 | 2 | 02-21-2005 01:32 PM |
Question for Procontrol Users | airwavejoel | ProControl, Control|24, Command|8 | 2 | 05-10-2004 07:28 AM |
ProControl Question | back2mono | General Discussion | 2 | 01-08-2002 08:37 AM |
