Old 08-22-2005, 01:32 PM
NeXuS LE NeXuS LE is offline
Default Hard drives in LE
Hey all
Im using PT 6.9 L3 (pc) with an MBOX
Its a very stable setup and most of the time is brilliant. But I am noticing on each hard drive after ie closed pro tools and gone back into it or rebooted my machine each drive shows a 'digidesign databases' folder in it.
Conseqentally thy are all empty apart from my main drive i use for all my PT sessions.
The question I have is how do you stop PT from creating these folders each time?
Not a huge issue but i run a tight ship and hate mess and clutter.......
Cheers all hope i can help someone myself
Old 08-22-2005, 01:38 PM
spkguitar's Avatar
Default Re: Hard drives in LE
You don't.
Old 08-22-2005, 01:42 PM
'You don;t'
So there is no way to stop this
Im sure there must be a way.
'You don;t'
Old 08-22-2005, 01:49 PM
spkguitar's Avatar
No.
The digibase creates those databases everytime on any mounted drive. If there were a way to "unmount" a drive in windows, then you could stop that from happening, but that is not the case, and would render that drive useless until re-mounted.
Details about all of this can be found in the digibase guide.
Old 08-22-2005, 01:53 PM
Ok m8 thanks very much you certainly seem to know you stuff.
I have another question from that then if you may be so kind to help.
When importing audio ie a sample or vocal from my audio drive I usually go to import audio and do it that way.
Of course this is a much longer process than the prescribed DIGIDESIGN way on one of their tutorials where you view a pane on the right hand sid eof your screen and drag it across once youve auditioned the audio.
My question is with much a tampering i have moved the pane and cannot find it nor do i know what its called can you help me to locate it please
thanks
Old 08-22-2005, 01:58 PM
spkguitar's Avatar
Bottom right hand side of the edit window there should be a button that looks something like this: <<<
click it
Old 08-22-2005, 02:06 PM
Once again sir you are a ST*R
Thank you kindly for you words of wisdon....
Cheers
Hard drives? delgado 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-28-2009 04:33 AM
Portable hard drives vs. desktop hard drives NHH 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-02-2009 07:29 AM
SSD (Solid State Drives) Alleviating The Need For Two Hard Drives For PT? epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 30 04-13-2009 12:19 AM
Hard drives in LE NeXuS LE 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-22-2005 01:43 PM
Hard Drives alonzoslefthand 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 05-24-2002 01:30 PM
