Go Back   Avid Pro Audio Community > Other Products > The Drum Room
Old 07-26-2011, 03:27 AM
tobbenos tobbenos is offline
Default Do you compress and EQ Ezdrummer tracks?
Hi, everyone!
I have got the Ezdrummer plug-in, but my question is about drum plug-ins in general:
How "finished" are the samples and grooves that come within these plugs? Do you always split the drums into separate tracks and treat them with compressor/EQ individually, or do you only do this when going for special effects?
Restated: Shall I treat the ezdrummer output as what I would have turned opp in Pro Tools if I miced up a drumset, or shall I treat it as a drumsound tweaked and fixed by professionals (with EQ-ing and so on)?
Old 07-26-2011, 02:19 PM
Stig Eliassen's Avatar
Default Re: Do you compress and EQ Ezdrummer tracks?
You shall treat drums as any other source in the mix. How can I make this sound good? How can I make the drums work with the rest of the mix? Personally, I don't like EZDrummer. Too much eq and compression right out of the box, and I have a hard time making it sound decent. For some things, EZD can work as is.
So, you must do what sounds good. That's just how it is. How to react to what we hear - that's what we need to practice every day on every song.
Old 07-26-2011, 07:54 PM
I have gravitated to SD2, but I have ezdrummer as well. In all cases, I still add EQ, compression, buss compression and a touch of room reverb. I just get better results(and faster) than trying to do it all inside the plugin(which could also be a factor of old habits). I usually split out the drum sounds to separate AUX tracks, and sometimes will print to audio tracks(especially if the project may go to another studio).
Old 08-12-2011, 07:44 AM
DonaldM's Avatar
DonaldM DonaldM is offline
Following up on Albee, I ALWAYS split my drum tracks into sep tracks, and then print out to audio as dry as possible (within the limits of the samples themselves). Then EQ, compress each part to taste as I would using a live drums. Takes more time, but I think the results are worth it.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Old 08-12-2011, 07:20 PM
Julia B Julia B is offline
Definitely. I'm not as detailed, but I do split toms, cymbals, snare, kick, and cowbell or whatever. EQ, compress, sidechain whatever. It does take more time but the results are definitely worthy the effort.
Model : Intel(R) Core(TM)2 Quad Q6600 2.40GHz
IDC : 4x 32kB, Synch, Write-Thru, 8-way, 64 byte
L2 : 2x 4MB, ECC, Synch, ATC, 16-way, 64 byte line sz, 2 thds sh
Mainboard: DFI Inc. INF P35-R
BIOS : Phx Tech, LTD 6.00 PG 03/11/2008
Bus(es) : ISA X-Bus PCI PCIe IMB USB i2c/SMBus
MP APIC : Y
Tot Mem : 3.25GB DIMM DDR2 (WinXP)
Chipset: Intel P35/G33/G31 Proc
Front Side Bus Spd : 4x 266MHz
Mem Bus Spd : 2x 399MHz
(C:) : (250GB, SATA, 8MB Cache)
(D:) : (250GB, SATA, 8MB Cache)
Old 08-12-2011, 08:00 PM
EGS's Avatar
EGS EGS is offline
Originally Posted by tobbenos View Post
...Do you always split the drums into separate tracks and treat them with compressor/EQ individually...
Yes.
Click for audio/video demo
Click for resume
EZdrummer-routing tracks in pro tools Luke K The Drum Room 23 02-10-2015 02:12 PM
ezdrummer how to route to seperate tracks? Jim harris Virtual Instruments 6 04-19-2013 10:31 AM
aux tracks and EZDrummer orvillej 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-06-2010 04:36 PM
Problem with EZDrummer Midi tracks Artfuldodger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 03-31-2009 01:08 PM
what drum tracks do you compress skylab001 Pro Tools TDM Systems (Mac) 13 10-28-2005 04:31 AM
