Running out of CPU - Goliath Sound Library
I'm a new user and so I apologize if my question might seem obvious. I installed the Goliath Sound Library by East West and everytime I use my ProTools crashes and says that I'm running out of CPU power. Shall I increase my RAM or do you thin that my computer processor isn't really appropriate for that? Do you have any suggestions? Thanks in advance Massimo Mac OS X 10.5.8 MacBook Pro 2.4 Ghz IntelCore 2 Duo RAM 2 GB 667 Mhz DDR2 SDRAM MBox 2 Pro Tools LE 8.0 |
Re: Running out of CPU - Goliath Sound Library
go 4 gb ,and youll get more out of goliath play
but go 64 bit and get as much ram or should i say as much computer possible if you are gonna work with lot of play instruments when pro tools becomes 64 bit,play is a heavy duty resource eating application, and was originaly designed to be 64 bit engine and current RTAS is not very friendly with east west play engine if youre still having problems try use only one core and DAE audio level1 in pt |
We had better luck with the old colossus with Kompact. One of the engineers here owns it and it seems to be more stable than Play.
New Sound FX Library! | Enos | Partner Announcements | 178 | 04-16-2024 05:32 PM |
Transfer of Goliath library to a SATA drive | munit54 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-08-2009 05:10 PM |
Problem installing Goliath library for Structure | podusa | Virtual Instruments | 6 | 03-27-2009 02:42 AM |
Anyone running Goliath successfully on an external drive? | Groove Agent | Virtual Instruments | 1 | 08-14-2008 12:05 AM |
Structure - Goliath problem - not loading library | Lofty11 | Virtual Instruments | 2 | 06-30-2008 03:03 PM |
