How To Bring Region Into Track To Snap To Memory Marker?
How can drag a region into a track such that it will snap to a memory location?
Re: How To Bring Region Into Track To Snap To Memory Marker?
I dont think you can snap audio to a marker but if you hold down the windows key whilst dragging from the regions bin it will snap the head, the left part, to the edit cursor. Just place the edit cursor where you need the head of the region to be then hold windows.
You might be interested in spotting regions to a sync point aswell at this link. http://en.wikiaudio.org/Pro_Tools:_C...s_for_spotting Check page 26 of this guide for the shortcuts aswell, tells you a lot more than the simple spotting of the head, goes into much more. http://akmedia.digidesign.com/suppor...cuts_25688.pdf Peace
PTLE8 with an Mbox 2, for now!
Thanks very much. I did also find Spot Command pg 722 PT Rference Guide...
Thanks, |
Spot is a good idea, but in the future you can do this.
Place the region on the track and make sure your edit cursor stays there. Click the marker. Using the Grabber hold the start key and click the region. You can also copy audio that way by adding the ALT key to the mix.
Sign up for all things....AWESOME! Kris May the music move you |
snap end of region to grid? | pinnacle | Pro Tools 10 | 3 | 09-10-2012 05:46 AM |
Unwanted region-snap | Wasaia | Pro Tools TDM Systems (Win) | 2 | 07-08-2009 08:48 AM |
Snap to MARKER???? | teacherman | Pro Tools TDM Systems (Mac) | 6 | 09-17-2008 08:42 AM |
snap to marker | Siddhant Bhatia | Tips & Tricks | 4 | 10-08-2006 12:13 PM |
snap to memory marker? | Rob Macomber | Pro Tools TDM Systems (Mac) | 1 | 01-09-2002 12:18 AM |
