audio waveform is missing top half!!!!!
For some reason the audio file is missing the top half. I tried re-installing pt and it still does it when i try to record audio. Help!!!
Kevin |
Re: audio waveform is missing top half!!!!!
we need more info on your setup, are you using cheap pre-amps?
Check your setup and make sure that you dont have "draw waveforms rectified" selected. This is used to help reduce system usage for systems that need the extra Processing power for other actions.
This is what Im talking about BTW, let me know if this is your problem.
http://img140.imageshack.us/img140/3...ctifiedgc1.jpg |
Yes. You have the 'draw waveforms rectified' option enabled in preferences. Disable it.
Hp Probook 4530s. i3 Sandy. 4gig RAM TI/VIA Firewire expresscards. |
Half of video missing since PT 11 upgrade | melloj | Pro Tools 11 | 0 | 07-21-2013 08:39 AM |
Duplicated Clip is Missing Half a Beat | completeidiot23 | Pro Tools 10 | 1 | 08-05-2012 06:46 PM |
Crossgraded from LE 8.0.3 To PT 10. Missing half the plug-ins | ArKay99 | macOS | 4 | 04-28-2012 06:21 PM |
7.4cs3 half waveform bug? | buckaroo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 03-18-2008 02:31 AM |
Well, with more then half the DUC missing... | Captain_Pants | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 26 | 02-09-2003 12:52 AM |
