Korg NanoKontrol in PT MP9?
I originally posted this thread in the 'MP' forum, where Chris at Southside Music was kind enough to reply. However, the problem still exists, so I thought I'd post it here in hopes that maybe more folks would see it. I have Pro Tools MP9 in a Windows 7 SP1 64 bit machine with an M-Audio Fast Track Ultra 8R interface. I recently purchased the Korg NanoKontrol (version 1) after being assured it would work with my version of Pro Tools by the head of the recording dept at the local Guitar Center. However, after consulting with him, searching this forum, checking YouTube, and Googling the problem, I still can't get this MIDI controller to work. No matter what I try, it always ends up at a window that says Pro Tools cannot communicate with the installed MIDI device. Any ideas/instruction are welcome. Thanks.
Re: Korg NanoKontrol in PT MP9?
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
If it's like the NanoKontrol2 you have to hold a button sequence on the device while plugging in the USB cable to select what mode or app it's configured for. On the NK2 you hold Set Marker and Play to set it in HUI mode for PT - maybe that's it. Only other thing that comes to mind is if you installed/configured the drivers.
PT 2024.3 DP 11.31 VEP 7.x with various VIs NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11 MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11 MOTU M4 on MacBook Air M2 2023 Sonoma.4.1 |
Thanks, Chuck, for your input. Yes, I saw on a YouTube video the process of holding down those two buttons on the NanaKontrol 2. Unfortunately, the NanoKontrol 1 has no marker button, and nothing in the device's instructions mentions anything about holding any buttons down while plugging it in. I've downloaded and set up both the latest driver and the latest version of editor for this device from the Korg website. (I even tried an older driver and version of editor after the latest didn't seem to help). I've also set up HUI in the the preferences menu, but that only brought up the window that said "Pro Tools cannot communicate with HUI..." I sent a message to Korg's support dept. a week ago, but have received no reply, which perhaps tells me all I need to know about Korg. If anyone has any other suggestions, please keep them coming. Thanks.
Jim |
Did a quick search over morning coffee and found a couple of things that might help.
http://trikome.com/blog/2009/02/27/h...th-protools-8/ Here's a video from YouTube, but I'm not so sure about the initial step of changing the driver. I'd try the above first without the change. http://www.youtube.com/watch?v=WzTr7UpmJvQ
To Chris, (CW Sand): I have not tried this device outside of Pro Tools, and since Pro Tools is the only place I use any MIDI (the only DAW I use), I'm not sure where else I could try it. It does power up when plugged into a USB port. My MIDI keyboards (Yamaha & Roland) plug into the MIDI port on my M-Audio Fast Track Ultra 8R, and I've had no problems with them. Simply plug 'n' play. This is my first experience with a USB MIDI device.
To Chuck: I had already viewed and tried both of the solutions in the links you posted (also thinking the driver situation was weird in the YouTube video. And I had no luck trying to trick Pro Tools into thinking the NanoKontrol was an M-Audio keyboard.) I truly do appreciate your searching and suggestions, though. Jim |
Korg NanoKontrol in PT MP9? | jglunt2112 | Pro Tools M-Powered (Win) | 0 | 01-02-2014 08:23 AM |
Korg NanoKontrol & PT LE | lionelcollins | MIDI | 91 | 10-06-2012 01:57 PM |
Korg nanokontrol 2 with pT 10 | Peter Groom | Windows | 1 | 08-15-2012 01:45 AM |
help me test a nanokontrol app | eesn | MIDI | 3 | 03-14-2011 07:58 AM |
KORG nanoKONTROL/PT MP Question | jlfulp | MIDI | 2 | 12-06-2008 02:33 PM |
