Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
  #21
Old 08-17-2020, 07:38 AM
Oblivion777's Avatar
Oblivion777 Oblivion777 is offline
Default Re: MTRX Studio with HD I/O
Got it. Thank you Jeff.
Main DAW: MacPRO 7.1, 16-Core Xeon 3.2GHz, 196 GB RAM, OSX 10.15.2, HDX3, PT 2019.12 Ultimate, 2x UAD-2 PCIe Octo's, Raven MTZ, 1x HD Omni, 2x HD I/O's, 1x MTRX and some more cool stuff...
Auxilary DAW: MacBook Pro with Retina Display (2012), 2.6GHz quad-core Intel Core i7, 16GB RAM, OSX 10.13.6, PT2019 Ultimate, 1x UAD Apollo Quad Audio Interface /w Thunderbolt Interface (v9.x)
  #22
Old 03-02-2021, 07:26 AM
beatlogik beatlogik is offline
Originally Posted by Oblivion777 View Post
Okay maybe not really connected to this thread and probably a stupid question but hey...there are no stupid questions only stupid people, right? Anyway I have a fully analogue populated MTRX (48 channels, 32in 16out). And I have 2 HD I/Os and an Omni. So I need by default a HDX3 system, right? 2 connections for the MTRX, 2 for HD I/Os and 1 for omni... or can I cascade both HDs and the Omni?
BTW I didn’t connect the MTRX yet...so...
Interested to learn more about your use case needs using both the MTRX and the Omni in the same system...Omni for monitoring needs?
I ask as I am considering the MTRX Studio and currently own an Omni, so my monitoring needs would be covered with the MTRX Studio
  #23
Old 03-02-2021, 01:12 PM
creativecontrol's Avatar
Good question. Remember that the IO associated with the OMNI can not be used within the Monitor Profile construct in DADman. The IO on OMNI can certainly be used as standard Pro Tools analog and digital IO to augment that of the MTRX Studio however.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #24
Old 10-13-2022, 05:19 AM
Allar Allar is offline
Hello!
Found this old thread but it somewhat relates to my problem/question.
Current setup:
2pcs of HD I/O-->Sonnet Chassis including 2 HDX cards-->Optical thunderbolt 2 to iMac
Problem/question:
If I would want to add a Avid MTRX (or MTRX Studio) unit to this system can I still use the existing HD I/O converters? If yes then is there any downside doing so and how would the correct setup/connections be?
Reasons to get MTRX are SPQ, Dante and possibly more I/O.
Thank you!
  #25
Old 10-13-2022, 05:23 AM
Greetings,
Yes, the recommended way to deploy would be to fully hook up 64 channels (2x 32 channels of DigiLink) from MTRX Studio for example to HDX Card 1, then to hook the 2 HD IO units to HDX Card 2.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #26
Old 10-13-2022, 06:04 AM
Hello!
Many thanks Jeff!!
  #27
Old 05-18-2023, 08:26 AM
patmaki patmaki is offline
Hi Jeff/all, when connecting HD I/O to MTRX Studio+HDN, is there a limitation to sample rate during tracking? My goal is to be able to track 40+ channels at 96kHz.
I picked up a Carbon, but realized too late that I'd be limited to 24 channels of analog I/O (at 96kHz) so will be returning it and just trying to figure out the right config of gear to get. I've been using Apollos for 13 years so it's been a bit of a ramp to get up to speed on the in's and out's (-; of Avid hardware.
My use case is I have a physical console (cadac J Type) with 32 channels of input/AUX and 8 group channels and want to converters 'hard wired' to each of these 40 outputs.
Thanks,
Pat
  #28
Old 06-12-2023, 06:30 PM
Anyone know the answer to this?
  #29
Old 06-12-2023, 07:15 PM
There are no channel limitations with DigiLink. As stated previously, I would hook up MTRX Studio to HDN Port 1 and then 1 or 2 HD IO units to HDN Port 2.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #30
Old 06-14-2023, 03:24 PM
Thanks for confirming Jeff, that's great news. Would it be the same case when connecting the Omni up to HD I/O units?
First steps with MTRX Studio SMM Pro Tools | MTRX & MTRX Studio 228 05-25-2022 07:38 AM
MTRX Studio i/o Cheesehead Post - Surround - Video 9 02-21-2021 08:17 AM
MTRX Studio and MOM Awesomeness DonRWatters Pro Tools HDX & HD Native Systems (Win) 5 12-07-2020 05:23 AM
How to tune SPQ card in MTRX Studio nedd Post - Surround - Video 13 07-31-2020 09:55 AM
MTRX Studio - No AES?! Ryan Young Pro Tools | MTRX & MTRX Studio 23 02-23-2020 02:13 PM
