Old 04-06-2021, 08:28 AM
Nick Camaron Nick Camaron is offline
Location: Somewhere in the vicinity of Alpha Centauri, MW
Default Double EUCON activated window after selecting track
my work-automatism is: I select a track and then immediately hit "shift-s" to hear it solo.
However this "shift" sometimes (not always) results in another EUCON Plugin or pan window appearing impertinently in the upper left, concealing my edit window.
So I have to close it.
Can anyone confirm this?
Just immediately after selecting a track hit shift.
Do this a couple of times until another window will appear. You too?
(It does not happen when holding shift and selcting a track.
It does not happen when waiting a beat longer between selcting a track and hitting shift.)
This is a bit annoying. Anyone knows what this is and how to avoid it?
Thanks
Mac Mojave, 2021.3, S3, Eucon 4.7.4.10
Old 04-13-2021, 05:14 AM
Default Re: Double EUCON activated window after selecting track
Ha, odd that this doesn't appear to be an issue for anyone.
Old 04-13-2021, 12:56 PM
shooting from the hip, I suspect a setting in Eucon
Old 04-13-2021, 12:58 PM
haha.. I toggled so many options already
Old 04-13-2021, 01:09 PM
reichman's Avatar
reichman reichman is offline
I've seen this, and I think it's caused by having a plug-in's parameters on the knobs, even after the plug-in window has been closed. Eucon thinks you want to see the next plug-in in the same slot and opens the window. Usually I go up a level on S3 or Dock and this goes away.
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 04-14-2021, 08:50 AM
EddieJones's Avatar
Try this one: Open Windows on Workstation When Knobs Assigned
Old 04-14-2021, 09:22 AM
hm. that completely disables the essential function I´m afraid.
I actually want that i.e EQ or Pan or whatever Plugin follows my track selection.
But only the "one" window in the "parked position" (the targeted) which simply switches the track(as indicated in the track selector).
But still often another or more windows appear on the upper left (with target symbol greyed out)
Old 04-15-2021, 09:21 AM
EddieJones's Avatar
Can I check...is this 2 plugin windows or a plugin window and a pan or send window ?
Old 04-15-2021, 09:50 AM
plugins only
I could reproduce with EQ3 7Band on tracks in a fresh session
Old 04-15-2021, 10:03 AM
EddieJones's Avatar
Can you post your EuControl general and Pref settings windows? And you just have an S3 and Control App ?
And tell me what button/mouse presses cause this io happen so I can try here.
Selecting track on S3 scrolls to view in Edit/Mix Window leggylangdon Avid S1, S3, Dock and Control App 6 01-27-2021 08:15 AM
Selecting tracks in Eucon? RecRoom Avid S1, S3, Dock and Control App 4 05-02-2020 11:15 AM
Double Clicking on Aux Track doesn't open Track Color window atothegreen Pro Tools 2018 17 03-28-2018 03:34 PM
Eucon / W10 Double click issue - BUG! Joris de Man Avid S1, S3, Dock and Control App 3 10-26-2017 07:45 AM
Keyboard shortcut for selecting next / previous track in Mix window? spinsah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-28-2009 12:37 PM
