Old 05-14-2019, 08:00 PM
mikeyman's Avatar
mikeyman mikeyman is offline
Default Freeze track
I think I understand what the Freeze feature is but can you tell me why I would use it .How does Freeze differ from Rendering.I have use Render before to cut down on CPU usage.Thanks
Old 05-15-2019, 12:34 AM
Sardi Sardi is offline
Default Re: Freeze track
By render, do you mean commit?
If so, they’re essentially the same thing. The difference being when you unfreeze something, all the settings on that track/channel re-appear and you continue as you were.
When committing, you’re essentially bouncing in place and discarding the prior track. PTs commit function is very well implemented in that you can keep the existing track but bypass it and hide it, or you can commit the track so that you can edit the rendered audio but still have the original there if you want to use it.
Which brings me to my final point, freezing won’t allow you to edit the frozen audio. It will play what’s on the track, but you can’t cut up the audio region.
Old 05-15-2019, 04:00 AM
amagras amagras is offline
Freezing for me is sometimes a great opportunity to move on and avoid infinite tweaking especially with VIs. When I finish a part I freeze the first VI or the amp sim to mark the end of the tracking/editing process and the beginning of the mixing process. It has helped me to work harder to get the right sounds during the tracking process. Another advantage over commit is that it doesn't add any extra tracks and it's easier to go back if for some reason I need to make additional/quick edits.
amagrasmusic.com
Old 05-15-2019, 06:26 PM
mikeyman's Avatar
ok thanks guys I am understanding it beter now.Very cool of Avid to give these other options...thanks a lot for your replies
Track Freeze vs Track Commit DonaldM Pro Tools 12 35 02-04-2016 08:08 AM
offline bounce from Send or Track outputs - track "freeze feature" OliverH Pro Tools 11 20 05-25-2014 04:45 PM
track Freeze in PT bbbkink Windows 10 12-11-2012 09:10 PM
Track offset menu or track freeze as workaround for ADC? mixaudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 10-27-2008 12:19 PM
