Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
Old 11-13-2018, 08:00 AM
frenchman frenchman is offline
Default Found another offline commit bug on HDX
I have a issue with a particular combination of plugins, it commits perfectly in HDX in real time, but not in offline mode
I can describe very simply :
1-mono audio track
2-Insert a mono/stereo ModDelay
3-inactivate it
4-Insert a second AAX DSP plugin behind (EQ III for example). It will instantiate in stereo of course since the previous plugin, even inactivated, is mono to stereo
5-Commit :
a) In HDX real time : OK, stereo file with same level on both channels
b) Offline : Not OK, stereo file but signal is left channel only
If second plugin is converted to Native, it works offlline. Thus it is probably a HDX DSP issue
just in case you ask I think the "why" this configuration is unrelevant here, this should not happen
Best regards
mark
Mac Pro late 2013 3,5 GHz 6-Core, Sierra, 16GB ram, Pro Tools Ultimate 2018.10
Mark Haliday
Engineer, Producer
Old 11-22-2018, 08:25 AM
Default Re: Found another offline commit bug on HDX
Bump
anyone seen this ?
Mark Haliday
Engineer, Producer
Old 11-23-2018, 11:35 AM
Confirmed here. Commit and Bounce to Disc behave the same. You should open a ticket with Avid and report it.
http://www.richbreen.com
MacPro 5,1 Dual Hex, OS 10.12.6, PT 2018 HDX, Avid HD I/Os and Metric Halo ULN8, Avid C24.
Offline commit/bounce paranoia abt Pro Tools 2018 6 11-13-2018 01:32 PM
PT hangs after initiating offline commit or bounce Mano Pro Tools HDX & HD Native Systems (Mac) 6 11-06-2017 01:19 PM
Another Commit bug found DJ Hellfire Pro Tools 12 0 12-23-2016 06:44 AM
pops and clicks in offline commit tracks fmo Pro Tools 12 3 03-07-2016 03:23 PM
Commit Sound Quality - or is it offline bounce? JKR Pro Tools 12 4 11-09-2015 03:08 PM
