Can\'t hear myself prior to the punch
I am using a 002. I select the "quick-punch" option. The tracks are playing and I am going to be punching the Vox track. I want to be able to hear the live vocals prior to the actual punch. I know this can be done but I am not sure how. Can someone help me out? Also, maybe it's just lack of technique, but on my punch (using quick punch method) I often hear what sounds to be a digital click. Other times it's clear as can be. Is there somthing I am doing wrong? Thanks guys/gals, Jesse |
Re: Can\'t hear myself prior to the punch
Set up an aux channel to the same input as the mic. This way you can hear what you're singing. It should work the same way with a mic input as it does with an instrument input. I actually discovered this by accident, because I could never hear anything unless the record was inabled. Then one day unbeknowns to me, I had an aux track with the same input as my keyboard, and I could hear it even without the rec being on, and while every thing else was playing. This made it cool, cause I could try nore ideas on the fly. I'm sure this is one way to do it
WLTruesongs |
Try selecting "INPUT ONLY MONITORING" in the software.
Docta'J Download free music at http://www.nukmusic.com nEVER uNDERESTIMATE kNOWLEDGE |
as far as the click when punching in is concerned.
under Setups/preferences/editing......at the bottom of the window set quickpunch crossfade length to 5 ms. this will eliminate the click. make sure this is set everytime when you start a new session and should be the first thing (and really the only thing) you need to check if you experience this click again. |
thanks everyone. You have solved my problems
Quick punch.... can't hear track audio until I punch in | stainless | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 07-31-2017 02:11 AM |
How do you punch in and still hear the track? | Ihatecomputers | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-02-2011 02:22 PM |
CAN I HEAR RECORDED TRACK AND PERSON THAT WILL PUNCH IN | MASTERLINKSTUDIOS | Pro Tools TDM Systems (Mac) | 20 | 01-09-2008 07:04 PM |
Record Punch Problem: Hear old take/Record new take | Felix Rost | Pro Tools TDM Systems (Mac) | 5 | 01-04-2008 11:29 AM |
No audio during punch in - hear the previous take | NTK | Pro Tools TDM Systems (Mac) | 5 | 08-17-2007 01:57 PM |
