Old 10-21-2020, 06:47 AM
TristanDuforestel TristanDuforestel is offline
Default "in page error occurred" - Impossible to start
Hi everyone,
I recently tried to reopen PT after a few weeks, with admin rights. It first starts normally, with the purple loading window and the big full screen one. But instead of the normal dashboard, I see two blank windows
When I click on the upper one, a pop-up, it prompts the message : "In page error occurred", without any more info like an error number (see attached image). From now on all is blocked. When I close this pop-up, it instantly reopens with the same message every time, even preventing me from closing PT. I have to use the task manager to do so.
The same happens when I directly try to load a session : before anything within PT works, this pop-up windows appears and blocks everything.
I tried to reinstall PT many times, none of which changed anything.
I have the 2018.1.0 version, with a Scarlett 2i4
I recently had to check my SSD hard drive with CheckDrive, which may have changed some stuff on it. But I did new PT setups from there which didn't change anything.
Here's the Sandra report :
SiSoftware Sandra
ID
Host Name : DESKTOP-VDNJKAA
Workgroup : WORKGROUP
Computer
Model : MSI MS-7C13 Default string
Serial Number : Default*******
Chassis : MSI Desktop
Mainboard : MSI H310M PRO-VD PLUS (MS-7C13)
Serial Number : J5161*****
BIOS : AMI (OEM) 1.30 04/12/2019
Intel vPro : 11.8.60.3561
Total Memory : 16GB DIMM DDR4
Processors
Processor : Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz (2C 4T 4.29GHz/4.6GHz, 4GHz/4.3GHz IMC, 2x 256kB L2, 12MB L3)
Socket/Slot : FC LGA1151
Chipset
Memory Controller : MSI Core8S (CofeeLake-S 6C) Host Bridge/DRAM Registers 100MHz, 16GB DIMM DDR4 2.67GHz 64-bit
Memory Module(s)
Memory Module : Crucial/Micron CT16G4DFD8266C16FE 16GB DDR4 2Rx8 PC4-21300U DDR4-2666 (19-19-19-43 4-62-20-7)
Video System
Monitor/Panel : LG 24BK450H
(1920x1080, 21.7")
Video Adapter : NVIDIA GeForce RTX 2060 (1920S 30C SM6.4 1.36GHz/1.68GHz, 3MB L2, 5.9GB 14GHz 192-bit, PCIe 3.0 x16)
Graphics Processor
CUDA : NVIDIA GeForce RTX 2060 (1920S 30C SM7.5 1.36GHz/1.68GHz, 3MB L2, 6GB 13.6GHz 192-bit)
OpenCL : NVIDIA GeForce RTX 2060 (1920S 30C SM1.2 1.36GHz/1.68GHz, 3MB L2, 6GB 13.6GHz 192-bit)
D3D 11 : NVIDIA GeForce RTX 2060 (1920S 30C SM12.1 1.36GHz/1.68GHz, 3MB L2, 5.9GB 13.6GHz 192-bit)
OpenGL : GeForce RTX 2060/PCIe/SSE2 (6GB)
Storage Devices
Disk : ADATA SU650 (480.1GB, SATA600, 2.5", SSD)
Disk : TOSHIBA HDWD110 (1TB, SATA600, 3.5", 7200rpm)
Optical : DRW-24D5MT (SATA150, DVD+-RW, CD-RW)
Logical Storage Devices
System Reserved : 579MB (NTFS, 4kB) @ ADATA SU650 (480.1GB, SATA600, 2.5", SSD)
Volume (F:) : 932GB (NTFS, 4kB) @ TOSHIBA HDWD110 (1TB, SATA600, 3.5", 7200rpm)
Hard Disk (C:) : 447GB (NTFS, 4kB) @ ADATA SU650 (480.1GB, SATA600, 2.5", SSD)
Optical Drive (E:) : N/A @ DRW-24D5MT (SATA150, DVD+-RW, CD-RW)
Peripherals
LPC Hub Controller #1 : MSI Intel(R) 200 Series Chipset Family LPC Controller - A2CA
Audio Device : MSI ICH200 (Union Point) HD Audio
Audio Device : nVidia TU106 High Definition Audio Controller
Audio Codec : nVidia GeForce 7800 GS
Serial Port(s) : 1
Disk Controller : MSI ICH200 (Union Point) SATA controller [AHCI mode]
Disk Controller : MSI ICH200 (Union Point) PMC
USB Controller #1 : MSI ICH200 (Union Point) USB 3.0 xHCI Controller
USB Controller #2 : nVidia TU106 USB 3.1 Host Controller
SMBus/i2c Controller #1 : Intel ICH SMBus
Printers and Faxes
Printer : Microsoft Software Printer Driver (300x300, Colour)
Printer : Microsoft Print To PDF (600x600, Colour)
Printer : Canon TS5000 series (Colour)
Biometrics
Voice : Analog NUI Voice Virtual Sensor (Voice)
Network Services
Network Adapter : Realtek PCIe GbE Family Controller #6 (Ethernet, 1Gbps)
Wireless Adapter : ASUS PCE-N10 11n Wireless LAN PCI-E Card #3
Operating System
Windows System : Microsoft Windows 10 Professional 10.0.18362
Platform Compliance : x64
Performance Enhancing Tips
Warning 2513 : TPM not detected. Some security features are unavailable.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
I hope i gave enough infos.
Anyone's got an idea on how to solve this ?
Thanks a lot !
Getting "Access violation occurred-unable to read location" error in 2019.10 Jasconito Pro Tools 2019 3 11-03-2019 01:59 PM
AAF , Tempo "varies" and Assertion Error, Import impossible joachim Post - Surround - Video 10 08-14-2019 07:48 PM
PT10/Digi 003 - Error occurred while trying to load the controller personality "003" J-Xile 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-14-2015 08:36 PM
Help? sudden error repeats: "access violation occurred" jojo99 Pro Tools M-Powered (Win) 5 01-26-2009 09:20 PM
Always Got "Access violation occurred" when start a new file Patrrchan35 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-25-2002 10:02 AM
