Old 09-16-2018, 11:28 AM
danyg danyg is offline
Default Dither
Hi, when I use "export clip as file" from a 48k session to 44.1 protools applies the old "bad" Dither. I know from another thread. I consolidated my master with Goddhertz Dither to 16b still in my 48 session
My question. When I do "export clip as file" for this 16 bit file now, does Protools understand that it doesn't has to Dither again when I choose 44,1 16 bit ?
Mac Studio - Ventura- 64 Gb ram - SSD int 2T - SSD ext 4T - Antelope Galaxy 32
Old 09-16-2018, 11:44 AM
BScout BScout is offline
Default Re: Dither
No. If you want to use your own dither on SRC or bit depth change, you need to use bounce to disk. Every other way, Pro Tools will "intelligently" apply dither.
When you applied Goodhertz Dither, you didn't create a 16 bit file. You zeroed out bits 19-24 (replaced everything with 0s) but the file still has 24 bits -- just eight are now 0. So Pro Tools still sees a 24 bit file and so still treats it like one.
Old 09-16-2018, 01:05 PM
Default Re: Dither
LOL - not that intelligent though
thank you for the quick answer BScout
Old 09-16-2018, 10:50 PM
digibase digibase is offline
Default Re: Dither
What is the best Dither plugin to apply ?
Old 09-17-2018, 12:20 AM
Default Re: Dither
I use Goodhertz for the visual control. But any decent Limiter Plugin has a Dither function (Ozone, Sonnox, Waves, etc...)
Old 09-17-2018, 09:34 AM
7Seas's Avatar
7Seas 7Seas is offline
Default Re: Dither
What’s wrong with the PT “bad” dither? I use it for my bounces... Anything I should be aware of?
Thanks.
Old 09-17-2018, 11:20 PM
Default Re: Dither
interesting video with examples
https://www.youtube.com/watch?v=_pBdcYiEuqY
Old 09-18-2018, 08:32 AM
Default Re: Dither
Yup. Pro Tools' lack of control over dither and SR conversion options on export has always seemed odd to me - In general I tend to export at whatever the native SR/bit depth of the session is and handle file conversions (SR and bit depth) in programs like Myriad or Wavelab.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 09-18-2018, 08:43 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Dither
Any dither is "good" if you're not doing a final WAV for CD plant -- AS LONG AS YOU DON'T DOUBLE-DITHER. That is bad.
I'm sure most of you wondering about this issue don't have monitoring that is capable of revealing the difference in blind test, but if you do, read this.
Janne
Old 09-18-2018, 09:04 AM
Default Re: Dither
Back to the OP for a moment; Dither would not be applied for going from 48K to 44.1K. It WOULD be applied for going from 24 bit to 16 bit(and you would want that). There is a place in the Preferences setup to choose the default dither
Goodhertz Good Dither — a world-class dither w/ simple controls goodhertz AAX Plug-ins 11 06-01-2015 04:41 PM
Can Dither in Export Prefs be changed to PowR Dither Mr. Anxiety Tips & Tricks 5 10-31-2009 10:28 PM
Dither ... placement of the dither plugin. tpthai2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-12-2007 07:20 AM
difference between POWr DIther and Dither benjaminbarry 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 07-21-2004 03:38 PM
PT DITHER x masterist dither x TC masterxdither x l1, q10 dither Alécio Costa Tips & Tricks 9 02-24-2002 01:28 PM
