Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 08-31-2018, 10:27 AM
Gyrobob Gyrobob is offline
Default "One or more tracks contain plug-ins not in your plug-in folder Xpand!2 "
When I open up PTF, I get "One or more tracks contain plug-ins that don't exist in your plug-in folder Xpand!2 (4)"
I searched other threads for info on this and found lots of stuff on plug-ins but not this particular issue.
I am still a less than newbie with PTF, so I am having lots of baffling situations like this.
Thanks for your patience.
On another subject, how do we delete threads on this forum. One of my other threads had no responses at all, and the problem went away anyway, so I would like to delete it.
Old 09-01-2018, 04:10 PM
junkgear's Avatar
junkgear junkgear is offline
Default Re: "One or more tracks contain plug-ins not in your plug-in folder Xpand!2 "
Have you installed Xpand? It’s a separate install.
If you did install it, then you should be able to find the aax file in the following location:
C:\Program Files\Common Files\Avid\Audio\Plug-Ins
If it’s not there, check the Plug-Ins Unused folder. If it ended up there, try moving it back to the plug-ins folder.
Will
System Details
Old 09-04-2018, 08:15 PM
I'm still getting the same message "One or more tracks contain plug-ins that don't exist in your plug-in folder Xpand!2 (4)"
Tobe Domingo sent this link to me and I downloaded it and opened it. XPand2_2018_3_Win_102997.zip
Now there are a bunch of aax files in C:\Program Files\Common Files\Avid\Audio\Plug-Ins
( see the pic )
The C:\Program Files\Common Files\Avid\Audio\Plug-Ins(unused) is an empty folder.
Old 09-07-2018, 07:07 AM
junkgear's Avatar
In that same folder, you should have a file for XPand with an aax extension.
If you don't have that, then Xpand is still not installed properly.
Will
System Details
"Plug-In Settings" sub-folder??? EGS Windows 1 08-19-2014 11:35 AM
Moving plug-ins to the "Plug-Ins (Unused)" folder lschultziv AAX Plug-ins 2 08-05-2014 09:18 AM
Import session data... please break out "plug in settings" and "plug in automation" yeloocevad Pro Tools TDM Systems (Mac) 19 10-05-2011 01:04 PM
Reason 3.0 "missing in plug in folder" C Walldorf 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-27-2009 03:10 PM
Message "Pro tools with tdm requires the tdm mixer plug-in in the plugins folder" Alexei Zaitsev Pro Tools TDM Systems (Win) 0 01-10-2009 03:48 AM
