Old 06-13-2018, 10:20 PM
SigFriedChicken's Avatar
SigFriedChicken SigFriedChicken is offline
Default "Cycle Playlists" shortcut logic
Does anyone understand the logic behind the "Cycle Playlists" shortcut (Shift+Up or Shift+Down)?
My expectation was that this shortcut would adjust the playlists so that either the second or bottom playlists are now the main playlist. But it seems to instead be grabbing playlists from seemingly random places (often from the middle of the playlists). Why would it pull from the middle? I can't figure it out any rhyme or reason to this.
Is there any way to just quickly move the bottom, or second, playlist to the main playlist. I know I can use promote, but then I have to do a bunch of extra legwork to preemptively relocate whatever is already in the main playlist so it doesn't get overwritten, and then rename the playlists, etc.
In general, the playlist ordering seems needlessly confusing.
Old 06-14-2018, 12:58 PM
Default Re: "Cycle Playlists" shortcut logic
I had forgotten that you can simply right-click on the main track and choose the desired playlist from the drop-down list. I can just use that. I can't believe I had forgotten about it.
I'm still confused about how the "Shift+Up/Shift+Down" playlist shortcuts work, but I guess I can live without them now that I remember the simpler right-click-and-pick-a-playlist method.
Old 06-14-2018, 02:46 PM
DAWgEAR's Avatar
DAWgEAR DAWgEAR is offline
If you create a first playlist and name it, e.g., "Playlist 1 and then subsequently create playlists named "Playlist 2", "Playlist 3", etc., it seems to cycle them in the order (or reverse order) in which they were created.
Pro Tools HD Native 2023.12 | HD Omni | iMac Pro 10-Core 3.0 GHZ - 64 GB - 2 TB - Vega 56 | Ventura 13.5 | Sonnet Echo Express SE II for PT HD Native PCIe and UAD 2 Quad PCIe card | Avid Dock and S1
Keyboard Shortcut for "Track List", "MIDI Editor Pane", and "Clip List" EdgarRothermich Pro Tools 12 2 10-04-2017 02:18 PM
Alt-Shortcut to reach "Edit" > "Automation" > joachim Windows 0 10-13-2014 08:14 AM
Pro Tools freezes - "restoring audio playlists" aldersyde Pro Tools 10 6 05-13-2014 03:40 PM
Difference between "Go to Song Start" and "Return to start of session" shortcut pericoloso Pro Tools 10 2 09-22-2013 12:44 AM
MC Mix connects correctly first time, "Network Error" after power cycle. A Chapman Artist Series 4 07-18-2011 03:04 PM
