"E:\ Code\ 222370\...etc???
Could not complete your request because Assertion in "E:\ Code\ 222370\ ProTools\ AAE\ Source\ AAX\ CFicAAXWidget.cpp", line 822.
WHAT THE HECK IS THIS?????????
Windows 10 Pro Tools 2019.6 Asus g752vt 17.3" laptop i7 Quad 2.6ghz 32gig ram 500gig ssd 2T ssd win. 10 Universal Audio x8P . Focusrite Clarett Octopre(NOT AN INTERFACE) |
Re: "E:\ Code\ 222370\...etc???
possibles: http://duc.avid.com/showthread.php?t=396615
remove cd/dvd if has one in drive plus other possibilities
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro PT 2023.3 Studio through an A&H Qu-32 |
I have done everything the you recommended on the other thread. This started right after I installed Andrew Schepps OMNI CHANNEL , and updated all the waves plugins and then rescanned them all.
Pull the Waves Shell out of the plugin directory and see if it goes away. At least you could confirm that it is related to the Waves plugins.
AAE = Avid Audio Engine AAX = the plugins CFicAAXWidget.cpp is possibly the plugin scanner ("cpp" is just compiled C++ code extension) If pulling the waveshell works, uninstall all the wave plugins, restart, reinstall all the waveplugins. Make sure after uninstalling that they are truly all gone (sometimes older waveshells will stick around) Also: Are you running Pro Tools as an Administrator? And where did you get "2018.3.1"? we're only up to "2018.3.0"
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 Last edited by BScout; 03-30-2018 at 03:09 PM. Reason: typo |
I vaguely remember having to reinstall Waves Update Center and all my waves plugins through WUC when I upgraded to 2018.1. Something to try.
Ok you're right pt 2018. 3:):) I will try uninstall.
Did you try it without the waveshell in the plugin folder? You haven't mentioned that. That should have been tried before trying to reinstall Waves. (to find out if it is an issue with a plugin)
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Nevermind. It has to do with audio playback configuration. unplug, replug the audient. reinstall drivers.
http://avid.force.com/pkb/articles/e...t-cpp-line-822
^^^ Probably
"d:\code\ws.protools_10.3.2\alturaports\dfw\views\ umenu.win32.cpp", line 1166 | theaudioeditor | Windows | 6 | 11-09-2012 04:14 PM |
how long did you wait for "free upgrade to PT9" download code? auto registration? | agypsy | macOS | 4 | 02-27-2011 02:49 PM |
Enter the "Activation Code" online fail | Butzenjay85 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 09-13-2009 01:09 PM |
Lost "Getting Started" Guide & Authorization Code | AndyDigi001 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 09-16-2008 08:26 AM |
"Error Code -6031 was returned by the Direct I/O driver." | Groovy C | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-28-2001 08:32 AM |
