Old 03-29-2018, 05:58 PM
Trin382 Trin382 is offline
Default "The original MIDI device associated with the MIDI controller HUI could not be
"The original MIDI device associated with the MIDI controller HUI could not be located. Please choose an existing MIDI device in the MIDI controller section of the peripherals dialog." New to DAW's in general so I did as Pro Tools instructed. I still continue to get the same message. I also have Ableton Live and it starts working immediately. I have also tested my MIDI keyboard on outside plugins (Analog LAB 3, Composer Cloud EW) and they work immediately on there as well. Not sure what the issue is. Please help? Thank you!
Old 03-30-2018, 02:46 AM
ChuckS ChuckS is online now
Default Re: "The original MIDI device associated with the MIDI controller HUI could not be
You probably configured your device in Setup --> Peripherals --> MIDI Controllers. That is for configuring control surfaces, not keyboards. The terminology is confusing. Unconfigure it there and the error will go away.
PT 2024.3 DP 11.31 VEP 7.x with various VIs
NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11
MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11
MOTU M4 on MacBook Air M2 2023 Sonoma.4.1
Old 03-30-2018, 09:35 AM
Ah, okay. Thank you! I'll give it a try.
Old 07-26-2022, 11:14 AM
davidbdaniels davidbdaniels is offline
Worked for me. Thanx.
original midi device associated with midi controller m keyboard could not be located willl3 Windows 1 09-23-2017 05:29 PM
Can you "Paste to original location" for MIDI studioj11 Pro Tools 11 8 09-24-2013 02:28 PM
How to get into "Edit" using a MIDI controller bender-offender Eleven Rack 4 06-27-2011 12:03 AM
Original Peavey PC-1600 midi controller with PTHD8/9 Hamdi Pro Tools TDM Systems (Mac) 1 01-26-2011 10:18 PM
"Linking" midi keyboard controller to NI unclestanky 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-13-2003 06:31 AM
