Old 10-28-2009, 05:15 PM
Mr. Anxiety Mr. Anxiety is offline
Default Can Dither in Export Prefs be changed to PowR Dither
Hello,
When I go to Preferences in 7.3 to select which dither plug to use, I only get Digidesign Dither as an option, even though I have PowR installed. Is there a way to select another plug here?
Thanks,
Mr. A.
Old 10-29-2009, 10:47 AM
Third Eye Studios Third Eye Studios is offline
Default Re: Can Dither in Export Prefs be changed to PowR Dither
I don't think there's an option for that.
Old 10-29-2009, 02:41 PM
elicious elicious is offline
if you're referring to exporting a mix or a region as a file
then that dither is not user definable.
but if i read your request properly and you want to use your fav dither on a mix
then use bounce to disk and place dither on your master fader
and you can use whatever you prefer.
(but, maybe you already knew that.)
b.o.l.
e
ihatetyping
Old 10-30-2009, 08:29 PM
Thanks for the replies.
I did know about the Bounce to Disk, using PowR on the master fader, but I've been exporting files instead of bouncing for better quality, and that's why I've inquired about changing the dither plug for exporting.
Are there any other options?
Thanks again,
Mr. A.
Old 10-31-2009, 12:02 PM
Eric Seaberg's Avatar
Eric Seaberg Eric Seaberg is offline
To be honest with you, if you're sending the files to someone else for ANY reason, dithering should ALWAYS be done at the LAST possible moment. If you're planning on encoding to MP3, let the encoding software handle that (which really is academic since it's ending up data compressed).
If you're sending it to someone for MASTERING, let them add the dithering as they would, most likely, add digital processing which will degrade your 16-bit files.
Keep them at 24-bit as long as possible!!!
Eric Seaberg • San Diego, CA
A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S.
Old 10-31-2009, 10:28 PM
In this case, I was mastering my files for uploading to the music sites. This is why I was dithering in the first place. They wanted 16 bit-44.1 .wav files.
Mr. A.
Mac Pro 3.0 Ghz Quad Core OS 10.4.11 PT 7.3
HD3 x (5) 192D + (1) 192 w/ Analog card
Big Ben MoL3
POWr Dither kurt Digidesign Hardware & Software 3 12-25-2010 10:45 PM
question about POWr dither guy.fi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-29-2006 06:52 AM
Dither vrs POWr cary chilton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 05-16-2006 11:32 AM
difference between POWr DIther and Dither benjaminbarry 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 07-21-2004 03:38 PM
Is POWR Dither still in the game with HD Chris Townsend Pro Tools TDM Systems (Mac) 1 03-22-2002 12:03 AM
