Old 05-30-2005, 07:20 PM
lancejorton lancejorton is offline
Default Hard Drive Not Playable Audio Drive
I tried to open a session today and it told me my disc allocation was not correct. I checked the new allocation and said it was not ok. Then, it said my FW drive was not a playable audio drive (something to that affect) and asked if I wanted to copy all of the session audio to another drive. I used it last on Friday (2 days ago) and no problems. This is the first I've had problems with this drive. It's a Western Digital drive in a Mercury enclosure (Macsales.com) with an Oxford 922 chipset (same as 911 but FW800, i'm using the FW400 port).
From a Mac perspective, Disc Utility says it's fine and I can read all of the files on it. I tried switching FW ports with my other drive and no luck. Digi, I admit that I'm on OS 10.3.9 (unsupported) but have never had problems before now. So far I tried Disc Utility, rebooting, and switching the FW cable and port. Still same issue. I'm upgrading to Tiger now to see if that fixes it (by using a supported OS version).
Has anyone else seen this issue though? Thanks.
PS - Yes, files are backed-up.
lance
lance
Old 05-30-2005, 07:30 PM
Shawn Simpson Shawn Simpson is offline
Default Re: Hard Drive Not Playable Audio Drive
workspace browser. In the 'A' column, the drive is set to "T" and it needs to be set to "R" or "P".
Search the forum for "volume not suitable for playback" and you'll find about a million other threads on the subject. Have fun!!
On occasion, Pro Tools determines (wrongfully) that a worthy firewire drive is not worthy. You can crown it worthy once more by going into the workspace. In there, you will see two columns marked A(udio) and V(ideo). In each column, for your firewire disk, there is either a T(ransfer) or P(layback) letter. Change that letter to R(ecord) and your drive will function as it did before.
Digi, please fix this bug! It dates back to v6.4.1 (at least)!
Old 05-30-2005, 07:33 PM
thanks guys. i'll try that when Tiger is ready. i did a few searches but didn't immediately find anything. so i tried a post. probably good to refresh it anyhow. thanks again.
lance
lance
Old 05-31-2005, 08:33 AM
DigiTechSupt's Avatar
Lance -
Did you install any new software, update your OS or connect the offending drive to another computer recently?
Avid Audio Tech Support
Support FAQ
Old 05-31-2005, 10:32 AM
Lance -
no, i didn't. the drive hasn't moved. i went ahead and installed Tiger and that reset the Workspace settings for me. everything works fine now. Digi, great job with Tiger! very smooth transition!
however, my CoreAudio problems remain. nothing but iTunes and Quicktime will play through CoreAudio. anything else won't connect.
lance
lance
DAE can't get audio from hard drive fast enough, hard drive may be fragmented, there huncke Pro Tools TDM Systems (Win) 6 02-23-2010 02:06 PM
Valid Audio Drive (hard drive issue) MacPro / HD3 owenpop Pro Tools TDM Systems (Mac) 5 01-11-2008 12:28 PM
Splitting my hard drive to create an audio drive? room51 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-17-2006 04:26 PM
PT not recognizing Hard Drive as audio drive Kevin P 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 09-20-2004 08:52 AM
Hard Drive Performance Dual Processors and Dedicated Audio Drive j_jayzatuc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-03-2000 05:52 PM
