Old 07-20-2004, 07:26 AM
benjaminbarry benjaminbarry is offline
Default difference between POWr DIther and Dither
I know this is such a newbie question but what it the difference between POWr Dither and Dither in Pro Tools Le? Why would Digidesign even include Dither if POWr Dither gives you the choice of three different noise shaping types?
Old 07-20-2004, 07:57 AM
spkguitar's Avatar
Default Re: difference between POWr DIther and Dither
The webpage seriously needs a new color scheme, but...
check this out.
Old 07-20-2004, 08:17 AM
Riad Riad is offline
If the text was in red I could have put on my 3D glasses... ugh.
www.carvelstudios.com
Old 07-20-2004, 07:15 PM
Thanks that helped a lot but I have one more question realated to POWr Dither. What is the difference between Noise Shaping types 1-3? Should one or another be used for different sound characters? Thanks.
ben.
Old 07-20-2004, 07:46 PM
lemix's Avatar
lemix lemix is offline
benjaminbarry ,
Good question,
I've read many instruction manuals, but as I recall none of them break it down as to which type is good for what. It really should be the user's choice by carefully listening the particular piece of audio they're working on.
I use some hardware converters that don't give any option, only on or off. However, most software dithers have these choices.
So, my advice is to start from type 1, and listen to the low level information, end of fades, reverb tails, etc...Then try type 2. Do the same thing..Than decide.
Should also try turning the NS off, use just plain dither. Listen.
good luck,
hope this helps a bit,
cheers,
cheers,
Andrew
W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx
Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more
2.0 and 5.1 monitoring
Old 07-21-2004, 03:38 PM
Yeah this definately helps. I will try to listen to the low level information and then decide for myself. It'll be some much needed 'ear practice' that all good producers/engineers need. Thanks.
POWr Dither kurt Digidesign Hardware & Software 3 12-25-2010 10:45 PM
Can Dither in Export Prefs be changed to PowR Dither Mr. Anxiety Tips & Tricks 5 10-31-2009 10:28 PM
Dither vrs POWr cary chilton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 05-16-2006 11:32 AM
POWr dither, or Cd recorder? cl516 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 07-12-2003 01:52 PM
Is POWR Dither still in the game with HD Chris Townsend Pro Tools TDM Systems (Mac) 1 03-22-2002 12:03 AM
