Old 09-18-2018, 11:04 AM
7Seas's Avatar
7Seas 7Seas is offline
Default Re: Dither
Any dither is "good" if you're not doing a final WAV for CD plant -- AS LONG AS YOU DON'T DOUBLE-DITHER. That is bad.
I'm sure most of you wondering about this issue don't have monitoring that is capable of revealing the difference in blind test, but if you do, read this.
Thanks!
Old 09-18-2018, 03:07 PM
ZEUSS ZEUSS is offline
Default Re: Dither
I am still surprised after all these years we cannot choose a third party dither when "exporting clips as files". Or even NOT to. Would be nice. Same with SRC. Maybe it will change some day.
Mac OS 12.7.2 Monterey (19H15) Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2024.3.1
Macbook Pro, 2019 (15,1) Mac OS 13.6.6 Ventura,32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2024.3.1, Apollo 8 Silver,TwinX.
Old 09-18-2018, 03:10 PM
JFreak JFreak is online now
Default Re: Dither
I haven't seen it a problem as this is not a final product. Care to elaborate why this is so important? For a single clip?
Old 09-18-2018, 03:54 PM
Default Re: Dither
I like to assemble my final mastered parts with Protools in whatever resolution say 24/96. When exporting 16bit/44.1 final for CD, you are forced to use AVID SRC or their dither.
Workaround is to Export in high rez and SRC/Dither with izotope etc in another daw.
Would save a step to be able to select say Goodhertz or MBIT etc and export to 16/44.1
Old 09-18-2018, 04:09 PM
Default Re: Dither
No, you are not forced to. You can for example have a Waves limiter that has dither to do the job for you (when you bounce your master)... What you are looking for is selecting dither for a clip export (?) which is not an end product at least as I see it...
Old 09-18-2018, 04:38 PM
Default Re: Dither
To give an easier explanation, I have a session at 24/96. I do a mix print by recording to a track. Now I want to make a ref thats 16/44.1. I can just export the file using "export clips as files". Done. But its using the ****ty SRC/Dither like the OP said. You can't choose a 3rd party. Only bouncing to disc does not automatically dither/noise shape..... That is an "End Product"
Old 09-18-2018, 06:56 PM
Default Re: Dither
One simple change in your technique would solve this. Instead of exporting your 2-mix, insert the dither of your choice on the mix track, solo the track and Bounce to Disk(real-time of off-line) and set the BTD settings to give a 16 bit/44.1K file. This way, you are in complete control over dither. With off-line bounce, this only adds a minute or less(a small trade-off for solving your issue)
Old 09-18-2018, 07:03 PM
Default Re: Dither
Yeah. I have done it that way as well. But there are other scenarios where It would be great if I we could choose our destiny! lol!! Honesty its supposed to be the top of the line industry standard DAW. This is just another old thing that I think they should update to bring it into a more modern environment. Their algos are SOOOO old!
Old 09-18-2018, 07:23 PM
Default Re: Dither
Exactly. Two different purposes.
Old 09-18-2018, 07:24 PM
Default Re: Dither
Old is bad? I'll take your 50's strato any day...
Goodhertz Good Dither — a world-class dither w/ simple controls goodhertz AAX Plug-ins 11 06-01-2015 04:41 PM
Can Dither in Export Prefs be changed to PowR Dither Mr. Anxiety Tips & Tricks 5 10-31-2009 10:28 PM
Dither ... placement of the dither plugin. tpthai2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-12-2007 07:20 AM
difference between POWr DIther and Dither benjaminbarry 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 07-21-2004 03:38 PM
PT DITHER x masterist dither x TC masterxdither x l1, q10 dither Alécio Costa Tips & Tricks 9 02-24-2002 01:28 PM
