Old 03-24-2016, 07:22 AM
frcjt frcjt is offline
Default Aae -9173
what to do?
Old 03-24-2016, 01:06 PM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Aae -9173
http://avid.force.com/pkb/articles/e...CPU-power-9173
Try that.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 03-24-2016, 03:17 PM
sw rec sw rec is offline
Start by giving us complete system info, as opposed to ZERO info......
Old 03-25-2016, 03:41 AM
MacBook Pro (17-inch, Early 2011)
2.3 GHz Intel Core i7
8 GB 1333 MHz DDr3
El Capitan
no plug-ins activated; only three tracks of live recording
anything else?
the error message makes no sense as I wasn't using ANY plug-in
as far as removing goes, does it mean remove from the system altogether?
Old 03-25-2016, 11:23 AM
happened again
just playback. no plugins. three tracks
i opened the CPU meter and it shows things at around 8%-10% and then the gauge starts swinging up, higher and higher, like a wave in the sea.
there are also noises, like crackling
is there nowhere in my system I can find some kind of log to see what's happening?
Old 03-25-2016, 11:50 AM
YYR123's Avatar
YYR123 YYR123 is offline
Default Aae -9173
Yeah the Mac have an event monitor, I believe that's what it's called.....
Spotlight "Monitor"
Daniel
Old 03-25-2016, 02:18 PM
helpful!
what i see is something called the "Pro Tools QuickTime Server (Not Responding)"
i've attached a snapshot
any ideas?
File Type: jpg Screen Shot 2016-03-25 at 11.03.14 PM.jpg (55.1 KB, 0 views)
File Type: jpg Screen Shot 2016-03-25 at 11.02.53 PM.jpg (61.6 KB, 0 views)
Old 03-25-2016, 03:37 PM
Southsidemusic's Avatar
What Drive is in that Macbook and do you record to that aswell or have you got the second drive needed if you have a spinner at 5400rpm as many of the older macbooks had?
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 03-25-2016, 08:27 PM
dr_daw's Avatar
dr_daw dr_daw is offline
Roll back to your back up of Yosemite. El Cap offers nothing in benefits for Pro Tools. Did it run before updating?
FBR recording - https://www.facebook.com/fromthebase...cordsrecording
@FBRrecording - Instagram
Rig
MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors
Old 03-25-2016, 09:09 PM
spin rate for the 500GB is 7200-rpm in the specs. that's what i have:
internalHD Hitachi HTS725050A9A362 500.11GB 7200rpm
externalHD Firewire AVASTOR HDX 1000GB 7200rpm
PT 12 - When 9173 is not actually 9173? taft_mashburn Pro Tools 12 2 10-06-2015 09:28 PM
Cpu 9173 mistermackum Pro Tools 11 1 12-20-2014 02:20 AM
PT 11 Clearly Not An AAE 9173 Error rgconrad1 Pro Tools 11 3 09-29-2014 11:56 PM
Aae-9173 txrx Pro Tools 11 5 12-28-2013 04:34 PM
