Old 01-13-2013, 08:15 PM
boogiemotel boogiemotel is offline
Default Best Remote Way to Run PT from Laptop or iPad
What is the best way to drive PT from a laptop ? how about an Ipad ? the Ipad is an app, right ? and which one really works ?
Old 01-14-2013, 12:31 AM
zolko zolko is offline
Default Re: Best Remote Way to Run PT from Laptop or iPad
The best way to drive PT from a laptop is to drive it from a laptop.
I saw Ipad. It is not an app but looked like piece of hardware :)
http://lmgtfy.com/?q=ipad+daw+controller
Old 01-14-2013, 01:01 AM
nigelpry's Avatar
nigelpry nigelpry is offline
I use Neyrinck's V-Control Pro on my iPad.
Wonderful on those occasions when I need to be in the live room with the musician(s) and don't want to keep going back and forth to/from the control room to set Pro Tools recording.
It can do a lot more, but I mainly use it to start/stop recording/playback, adjust fader levels, watch meter levels etc.
It will even let you display one other window (from outside pro tools) from your computer. I often use it to display a txt file with the song lyrics on it, useful for discussing phrasing etc.
I can do all that from the iPad via wi-fi.
Check out V-Control Pro, it really is quite good.
Cheers,
Nigel
Old 01-14-2013, 06:51 AM
tooold's Avatar
tooold tooold is offline
I'm also using V-Control Pro. Works very well. You can save and undo from the iPad, as well as all the stuff you'd think it would do. Setup is straightforward and the developer is very responsive.
It also gives you the option to have a second window which, in my case, I use to control my ULN-8, so if I need to change a mic pre gain or something, I pop open the window, make the adjustment, and I don't have to leave my seat. I'm engineering myself, so it makes life easier and saves a lot of steps.
2015 nMP 64Gb RAM, OS 10.12.5, PT Native 12.8.3, Metric Halo ULN-8, LIO
Old 01-14-2013, 07:21 AM
bobcats bobcats is offline
V Control Pro
Hands down the best Protools / IPAD App that exists
You will wonder how you lived without it.
Old 01-14-2013, 07:51 AM
dj_grimmace dj_grimmace is offline
Another vote for V Control. I'm the only sound designer at a small game dev company and I use it all the time for recording foley and sfx. Well worth the $$.
Best way to remote trigger recording in PT via iPAD/iPhone NJ Soul Pro Tools M-Powered (Win) 1 10-26-2010 10:23 AM
Which Remote controller for the iPad and PT? michael c Pro Tools TDM Systems (Mac) 5 04-05-2010 02:13 PM
Using Laptop and VPN to remote connect Ford 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-17-2006 01:22 PM
Can my PC Laptop record a remote track for my MAC? Blue Ridge 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 02-25-2005 12:02 AM
Remote PT via Laptop?? dither Tips & Tricks 31 03-14-2002 09:03 AM
