Run as administrator issue - either drag and drop or elastic audio broken
I have a really annoying issue with PT11HD. I get an Elastic Audio error on booting PT11:
c:\Program Files\Avid\Pro Tools\System Plug-Ins\Elastic Audio.aaxplugin could not be loaded. Please contact the software publisher for support using this software: Error details: Import DLL iZotope_Radius_XForm_x64.dll cannot be loaded If I set ProTools.exe to run as administrator (right click > Properties > Compatibility tab > tick Run this program as administrator) the above error message goes away and Elastic audio works as expected. However, with run as administrator enabled, I can no longer drag and drop wav files to the timeline or the clip pane. Damned if I do, Damned if I don't. Any ideas on how to resolve this would be very much appreciated. I am running PT11HD on windows 8 x64, with an RME fireface 800 interface. _______ Sisandra report: SiSoftware Sandra ID Host Name : t-tomad-t35 Domain : EUROPE Computer Model : Dell Precision WorkStation T3500 Serial Number : 6FQ**** Chassis : Dell Tower Mainboard : Dell 09KPNV Serial Number : ..CN7082********* BIOS : Dell A11 04/20/2011 Total Memory : 12GB ECC DIMM DDR3 Processors Processor : Intel(R) Xeon(R) CPU W3690 @ 3.47GHz (6C 3.6GHz, 2.66GHz IMC, 6x 256kB L2, 12MB L3) Socket/Slot : FC LGA1366 Chipset Memory Controller : Dell X58 I/O Hub 2x 3.19GHz (6.38GHz) Memory Controller : Intel Server (Gulftown) Uncore 2x 3.19GHz (6.38GHz), 3x 4GB ECC DIMM DDR3 1.33GHz 192-bit Memory Module(s) Memory Module : Hynix (Hyundai) HMT325U7BFR8A-H9 2GB ECC DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Hynix (Hyundai) HMT325U7BFR8A-H9 2GB ECC DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Hynix (Hyundai) HMT325U7BFR8A-H9 2GB ECC DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Hynix (Hyundai) HMT325U7BFR8A-H9 2GB ECC DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Hynix (Hyundai) HMT325U7BFR8A-H9 2GB ECC DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Hynix (Hyundai) HMT325U7BFR8A-H9 2GB ECC DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Video System Monitor/Panel : Dell Computer DELL 2208WFP (1680x1050, 22.0") Monitor/Panel : Dell Computer DELL 2209WA (1680x1050, 22.0") Monitor/Panel : MJI marantz-AVR (1920x1080, 91.0") Video Adapter : AMD Radeon HD 7800 Series (16CU 1024SP SM5.0 860MHz, 2GB DDR5 4.8GHz 256-bit, PCIe 3.00 x16) Video Adapter : AMD Radeon HD 7800 Series (16CU 1024SP SM5.0 860MHz, 2GB DDR5 4.8GHz 256-bit, PCIe 3.00 x16) Video Adapter : AMD Radeon HD 7800 Series (16CU 1024SP SM5.0 860MHz, 2GB DDR5 4.8GHz 256-bit, PCIe 3.00 x16) Graphics Processor OpenCL GP Processor : AMD Radeon HD 7800 Series (1024SP 16C 860MHz, 2GB DDR5 4.8GHz 256-bit) Compute Shader Processor : AMD Radeon HD 7800 Series (1024SP 16C 860MHz, 2GB DDR5 4.8GHz 256-bit) Storage Devices SEAGATE ST3300657SS (300GB, SASCSI, SCSI-5, 3.5", 15015rpm) : 279GB (C:) WDC WD1002FAEX-00Y9A0 (1TB, SATA600, 3.5", 20000rpm) : 932GB (D:) WIBU - CodeMeter-Stick (41.2MB, USB1) : 39MB (F:) Kingston DT 100 G2 (8GB, USB2) : 7GB (E:) PLDS DVD+-RW DH-16ABS (RAID, DVD+-RW, CD-RW) : N/A (G:) Logical Storage Devices System Reserved : 350MB (NTFS) Data (D:) : 932GB (NTFS) @ WDC WD1002FAEX-00Y9A0 (1TB, SATA600, 3.5", 20000rpm) CODEMETER (F:) : 39MB (FAT32) @ WIBU - CodeMeter-Stick (41.2MB, USB1) Removable Drive (E:) : 7GB (FAT32) @ Kingston DT 100 G2 (8GB, USB2) Hard Disk (C:) : 279GB (NTFS) @ SEAGATE ST3300657SS (300GB, SASCSI, SCSI-5, 3.5", 15015rpm) Optical Drive (G:) : N/A @ PLDS DVD+-RW DH-16ABS (RAID, DVD+-RW, CD-RW) Peripherals LPC Hub Controller 1 : Dell LPC Interface Controller LPC Legacy Controller 1 : SMSC SCH5504-NS Audio Device : Dell HD Audio Controller Audio Device : Pine Technology Cape Verde/Pitcairn HDMI Audio [Radeon HD 7700/7800 Series] Audio Codec : ATI (AMD) HDMI Audio Serial Port(s) : 1 Parallel Port(s) : 1 Disk Controller : Dell ICH8R (ICH8) SATA RAID Controller Disk Controller : Dell SAS 6/iR Adapter RAID Controller USB Controller 1 : Dell USB UHCI Controller #4 USB Controller 2 : Dell USB UHCI Controller #5 USB Controller 3 : Dell USB UHCI Controller #6 USB Controller 4 : Dell USB EHCI Controller #2 USB Controller 5 : Dell USB UHCI Controller #1 USB Controller 6 : Dell USB UHCI Controller #2 USB Controller 7 : Dell USB UHCI Controller #3 USB Controller 8 : Dell USB EHCI Controller #1 FireWire/1394 Controller 1 : TI TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Send to Microsoft OneNote 15 Driver (1200x1200, Colour) Printer : Microsoft XPS Document Writer v4 (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Printer : Xerox WorkCentre 7545 PS (600x600, Duplex) Sensors Location : Microsoft Visual Studio Location Simulator Sensor (Location, Unknown) Peripherals Media Player : WIBU - CodeMeter-Stick (38.57MB) Media Player : Kingston DT 100 G2 (7.45GB) Network Services Network Adapter : Broadcom NetXtreme 57xx Gigabit Controller (Ethernet, 1Gbps) Operating System Windows System : Microsoft Windows 8 Professional 6.02.9200 Platform Compliance : x64 Windows Experience Index Current System : 6.1 |
Re: Run as administrator issue - either drag and drop or elastic audio broken
Bump... Anyone have any ideas about this problem?
Sounds like a corrupt installation of the EA. I would uninstall and re-install, and when you uninstall, if you have the option, REMOVE the HD driver too(this is regardless of whether you run HD hardware or not)
Drag-and-drop won't work on Windows if you RAS. If you need EA, use Ctrl+Shift+I to import audio.
Cheers,
Thanks Bruce - I am a sound designer working in post, and dragging and dropping sounds from my audio database to PT is an essential part of my workflow, I do it _constantly_ and I can't really do without it. Elastic Audio is also pretty essential too.
These are both bugs you hit. The elastic audio issue though is more likely an install issue. I would do a clean install.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
As I also said FWIW, 11HD(specifically 11.3) works great here, with no issues related to EA
I tried a re-install. I uninstalled all versions of pro tools (10.3.9 and 11.3) and then manually removed remaining folders and files from C:/Program Files and C:\Program Files\Common Files to get a clean install of PT11 HD.
Unfortunately this did not solve the problem, I still get the same error message. Strangely, the first time I booted, the error message did not appear and I was able to use EA, but since then, the error message is back. Anyone have any further suggestions? Is there something else I need to do in order to get a completely clean re-install? I suppose this is going to be some kind of software conflict, and I am probably going to need to completely start from scratch, installing things one by one until I find the culprit... ugh. |
You state 8,are you actually using 8.1? Not sure that matters but might. When uninstalling, selecting the option that deletes everything? Running the installer as administrator?
I didn't do this, but I think installers have to ask for admin privileges by default in any case, because they are modifying core windows directories (program files etc.) Certainly, when you run the installer, you get the typical "do you want to let this program modify your computer" type of dialogue, which is associated with giving admin rights. |
Drag and drop issue | yanos | macOS | 1 | 02-16-2015 02:51 AM |
Drag'n drop issue | yanos | Pro Tools 11 | 0 | 12-10-2014 05:06 AM |
Elastic Audio > drag drop loop > session not mapping to loop tempo | 440Hz | macOS | 3 | 07-04-2011 07:35 PM |
Drag & Drop Onto Arrange Window Broken PT8 | paulmellors | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-06-2009 02:44 PM |
PT 6.4cs9 with 001 Import/Drag-Drop Broken - Any help? | ChuckS | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-18-2007 09:18 AM |
