C600 stops working frequently
My Fast Track C600 behaves strangely since I bought it. Every now and then it simply stops working. Now sound output, but all application that rely on sound - audio players, video player, YouTube in a browser, stop playing (they continue to work, buffering data, but that's all). The only solution seemed to be unplugging the interface and plugging it back which was bringing everything back to normal.
Unfortunately hot-plugging also lead to frequent system crashes so I looked for another workaround which work for me now - I simply right click on the volume icon in the tray and activate playback devices list. Then I simply disable C600 and enable it again to get everything working again. I have no idea what can be a problem - is it my hardware/software combination (Windows 7 Ultimate, btw), or my is my unit defective? Needles to say, that drivers updates didn't change anything. Any ideas? |
Re: C600 stops working frequently
Can you post your full system specs? Have you gone through the Optimization Guide, specifically the part about disabling any power saving?
Personally, I don't run my system sounds through my interface as it causes more headaches than it is worth. Joel
Jam Space: HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Home: Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Rig: Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM |
Indeed^^^ the 2 things I would do are;
#1-set Windows to use the onboard audio output #2-make sure Power Management is OFF on all USB ports(called USB Root Hub in Device Manager. Other things to consider; if you are connected to a USB3 port, try a USB2 port. Post a Sandra report(see the Help us Help You link near the top of the page) so folks can look over the system hardware for any possible incompatible parts
I will try to use onboard audio but usually they are very noisy and I try to avoid them as much as possible. And 90% of my C600 usage is listening to system sounds.
I did all optimization steps described in the attached documents long time ago - no improvement since. My hardware specs: SiSoftware Sandra ID Host Name : STACJONARNY Workgroup : PIXELCROW Computer Model : GigaByte EX38-DS5 Chassis : GigaByte Desktop Mainboard : GigaByte EX38-DS5 BIOS : Award (OEM) F1 02/05/2008 Total Memory : 6GB DIMM DDR2 Processors Processor : Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz (2C 3GHz, 6MB L2) Socket/Slot : FC LGA775 Chipset Memory Controller : Gigabyte X38 Processor to I/O Controller 4x 333MHz (1.33GHz), 2x 3GB DIMM DDR2 666MHz 128-bit Memory Module(s) Memory Module : Kingston 2G-UDIMM 2GB DIMM DDR2 PC2-5300U DDR2-666 (5-5-5-15 3-20-5-3) Memory Module : Mushkin 991578 996578 1GB DIMM DDR2 PC2-8500U DDR2-1066 (5-5-5-18 3-23-6-3) Memory Module : Kingston 2G-UDIMM 2GB DIMM DDR2 PC2-5300U DDR2-666 (5-5-5-15 3-20-5-3) Memory Module : Mushkin 991578 996578 1GB DIMM DDR2 PC2-8500U DDR2-1066 (5-5-5-18 3-23-6-3) Video System Monitor/Panel : BNQ BenQ GL2450H (1920x1080, 24.0") Monitor/Panel : ACI ASUS VB191 (1600x1200, 19.1") Video Adapter : NVIDIA GeForce GTX 460 (7CU 336SP SM5.0 1.43GHz, 512kB L2, 1GB 3.61GHz 256-bit, PCIe 2.00 x16) Video Adapter : NVIDIA GeForce GTX 460 (7CU 336SP SM5.0 1.43GHz, 512kB L2, 1GB 3.61GHz 256-bit, PCIe 2.00 x16) Graphics Processor CUDA GP Processor : NVIDIA GeForce GTX 460 (336SP 7C 1.43GHz, 512kB L2, 1GB 3.61GHz 256-bit) OpenCL GP Processor : NVIDIA GeForce GTX 460 (336SP 7C 1.43GHz, 512kB L2, 1GB 3.61GHz 256-bit) Compute Shader Processor : NVIDIA GeForce GTX 460 (336SP 7C 1.43GHz, 512kB L2, 1GB 3.61GHz 256-bit) Storage Devices Seagate ST3500410AS (500.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) : 466GB (S:) Intel INTEL SSDSC2CT180A3 (180GB, SATA300, 2.5", SSD) : 168GB (C:) Seagate ST3500418AS (500.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) : 466GB (E:) GOODRAM C40 (120GB, SATA300/600, 2.5", SSD) : 112GB (W:) Western Digital WDC WD2500KS-00MJB0 (250GB, SATA300, 3.5", 7200rpm, 16MB Cache) : 233GB (D:) Western Digital WDC WD2500KS-00MJB0 (250GB, SATA300, 3.5", 7200rpm, 16MB Cache) : 233GB (F:) Western Digital WDC WD10EADS-114BB1 (1TB, USB2/SATA300, 3.5", 32MB Cache) : 932GB (I:) Logical Storage Devices SERIALE (S:) : 466GB (NTFS) @ Seagate ST3500410AS (500.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) Zastrzeżone przez system : 100MB (NTFS) STORAGE (E:) : 466GB (NTFS) @ Seagate ST3500418AS (500.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) WORK FAST (W:) : 112GB (NTFS) @ GOODRAM C40 (120GB, SATA300/600, 2.5", SSD) WORK (D:) : 233GB (NTFS) @ Western Digital WDC WD2500KS-00MJB0 (250GB, SATA300, 3.5", 7200rpm, 16MB Cache) FILMY (F:) : 233GB (NTFS) @ Western Digital WDC WD2500KS-00MJB0 (250GB, SATA300, 3.5", 7200rpm, 16MB Cache) BACKUP (I:) : 932GB (NTFS) @ Western Digital WDC WD10EADS-114BB1 (1TB, USB2/SATA300, 3.5", 32MB Cache) SYSTEM (C:) : 168GB (NTFS) @ Intel INTEL SSDSC2CT180A3 (180GB, SATA300, 2.5", SSD) Peripherals LPC Hub Controller 1 : Gigabyte (ICH9) LPC Interface Controller LPC Legacy Controller 1 : ITE IT8718F Audio Device : Gigabyte GF104 High Definition Audio Controller Audio Codec : nVidia 0012 Audio Codec : nVidia 0012 Audio Codec : nVidia 0012 Disk Controller : Gigabyte (ICH9) 6 port SATA AHCI Controller Disk Controller : Gigabyte JMB36X PCIE-to-SATAII/IDE RAID Controller Disk Controller : Gigabyte JMB36X PCIE-to-SATAII/IDE RAID Controller USB Controller 1 : Gigabyte (ICH9) USB Universal Host Controller USB Controller 2 : Gigabyte (ICH9) USB Universal Host Controller USB Controller 3 : Gigabyte (ICH9) USB Universal Host Controller USB Controller 4 : Gigabyte (ICH9) USB2 Enhanced Host Controller USB Controller 5 : Gigabyte (ICH9) USB Universal Host Controller USB Controller 6 : Gigabyte (ICH9) USB Universal Host Controller USB Controller 7 : Gigabyte (ICH9) USB Universal Host Controller USB Controller 8 : Gigabyte (ICH9) USB2 Enhanced Host Controller FireWire/1394 Controller 1 : Gigabyte TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Xerox Phaser 3010 (1200x1200, USB) Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : FinePrint 7 (1440x1440, Colour) Fax : Microsoft Shared Fax Driver (200x200) Printer : Xerox Phaser 3010 (600x600, USB) Network Services Network Adapter : Realtek RTL8168C(P)/8111C(P) Family PCI-E Gigabit Ethernet NIC (NDIS 6.20) (Ethernet) Network Adapter : Realtek RTL8168C(P)/8111C(P) Family PCI-E Gigabit Ethernet NIC (NDIS 6.20) #2 (Ethernet, 100Mbps) Network Adapter : TAP-Win32 Adapter OAS (Ethernet) Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 6.5 |
Looks like a rather old and under-powered computer, with a questionable chipset(incompatible chipsets can give lousy performance, or just not work at all). I don't recall ever seeing the X38 listed on any list of approved or working systems with Pro Tools
One added benefit of a newer system is, many have SPDIF outputs for the onboard audio. I feed mine to the optical SPDIF input of a Presonus Central Station and all my non-Pro Tools audio sounds just as good as PT audio thru my HD IO interface.
But I'm not complaining about Pro Tools performance, as I'm not using PT at all.
I'm using my C600 with all kinds of audio software and "ordinary" software and the problems are related to the interface not the software. This machine is old but is good enough for what I do, thank you very much. The DAW I use works quite fine on this setup. Everything else as well. Of course I would be glad to replace it, but it's much easier (cheaper) to buy a different interface (from different manufacturer next time) than to replace the whole machine at this moment. |
I see. I have no other ideas to offer, short of a better interface or a driver update. Maybe as a last resort, try ASIO4ALL.
Pro tools upgrade, my fast track C600 not working | mrfroiland | Pro Tools Express on Mac OS X | 2 | 07-30-2014 06:13 AM |
Tab To Transient Stops Working | ronstephens | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-29-2010 04:41 AM |
Tab to transinet stops working in 8.03 | garnoil | Post - Surround - Video | 0 | 01-05-2010 08:07 AM |
002 randomly stops working!! | reyalp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 10-24-2006 06:12 PM |
7.2 -- what stops working? | brucecoughlin | Pro Tools TDM Systems (Mac) | 2 | 08-29-2006 12:05 PM |
