Old 11-17-2004, 12:03 AM
Dopamine Dopamine is offline
Default Learning curve w/ C24
I'm starting a new job at a studio w/ a Control 24. I have plenty of PT skills, but have been limited to a mouse (except for some brief experience on Pro Control years ago). Any tips on how to make the best of the situation? The owner knows that I've never used the C24, however i need to make a great first impression during my first, 'trial' week. Any advice is appreciated!
http://www.phuturetrax.com
Old 11-17-2004, 12:13 AM
ajazzie ajazzie is offline
Default Re: Learning curve w/ C24
Try to get your hands on one somewhere for a few hours, The learing curve to get familiar with the 24 is not a hard thing, however you do have to get used to the idiosyncracies of it.
You really just need to get on one for a few hours, make yourself rely on it and not the mouse and you will pick it up quick.
Failing that, just use it as a mixer and continue to do your usual with a keyboard, mouse etc. untill you get comfortable with the 24. Using your keyboard shortcuts should be impressive enough, I have seen somany threads on shortcuts here, and in the right hands they are quick and raise eyebrows. Speed and ease are what makes a pro, that and confidence in knowing about the proceedures.
I still use both, however the mixing is so much faster with the surface, get used to automation as its one of the big advantages of mixing with it.
Good luck, here to help out if you need it,
AJ
A Gentleman is one who can play the bagpipes, yet chooses not to.
Old 11-17-2004, 06:50 PM
Thanks for the thoughtful reply and advice.... I'll let you know howe it goes!
Old 12-17-2004, 02:53 PM
unseen unseen is offline
Dop.,
If you're still reading this thread I have a quick question for you because I noticed you were starting work at a studio.
I own a small studio and I'm looking to hire an additional engineer/studio manager to take a majority of the sessions so I can focus more on my record label and producing select artists. If you don't mind me asking, is this a salaried position or do you make a percentage of the sessions, or are there other options?
Thanks!
Brian Morykon
Unseen Sound Studios
Check out Unseen Records artist Jacob Zachary
Steep Learning Curve For Me :-) Long! ValkRider Eleven Rack 1 09-10-2013 02:01 PM
learning curve from PT Le 7 to PT 10 ?? diggyfresh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-13-2012 07:26 PM
Pro Tools Learning Curve DJKeys macOS 14 07-19-2011 02:57 PM
PT learning curve rascalmanny 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 01-03-2003 01:14 PM
The 001 Learning Curve 3rdstory 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 18 10-29-2000 10:16 AM
