VERY Disappointing....
Hi...
After Running my digi on numerous, systems, its aparant that something is wrong with the digi, and not the many machines i've tried it on... As soon, as windowsXP starts to install Device drivers for the digi, the machine Blue Screens with the msg. "IO system verification error, or Bad Pool Caller"..... 'm at my whits end with this problem, and digidesign Mumbai, may not service it since "IT WASNT BOUGHT FROM THEM"....... Maybe the firmware of the digi got corrupt, is ther eany way with a combination of buttons to reset the system. Could the driver on the CD be Corrupt..??? Really need some help with this one.. Tried the digi on 2 different configs.. My system, is a 865GBF based, P4 3ghz, 1G ram, etc etc.. the laptop is HP 2.8ghz, 1gb, ram the other systems were, 865p, p4 2.8ghz 2gb ram, and 865 gbf p4 3ghz and 1.5 gb ram... BOYS AT DIGIDESIGN , NEED YOUR HELP... Fali Damania Head Engineer Flying Carpet Productions. Mumbai [email protected] Mob: 01191 9819009021 |
Re: VERY Disappointing....
which Digi?
Don't let windows install the drivers. The install should be done completely from the install disk without any help from windows.
I would look at drivers...Make sure anything not needed in the bioas is disables also. USB/Network Card (especially on board)....
Especially check all the IRQ's... From M$ sites.. INTRODUCTION This article describes how to interpret or read Stop 0xC2 error messages in Microsoft Windows XP. The Stop 0xC2 error message indicates that a kernel-mode process or driver incorrectly tried to perform a memory operation. Typically, faulty device drivers or device software cause this error message. Back to the top MORE INFORMATION Windows XP contains many features that enhance the pool allocation process for device drivers and other software. Microsoft added several new Stop error codes to help you locate drivers that do not work correctly. By using these features, you may be able to determine the cause of a driver malfunction through a debugging operation. http://support.microsoft.com/default...&Product=winxp |
Make sure you're following the installation instructions.. do NOT use the New Hardware Wizard.
Read the SP2 thread at the top of the forum. If you're running SP2 make sure you have the right Pro Tools version and check out the DEP fix. If you already tried installing incorrectly - you'll need to manually clean up... search the DUC for the words +dalwdm.sys +delete +Rail and you should find directions from me on how to clean your system. Rail
followed all the instructions, etc, and formatted hard drive, in frustration hahaha...
but still.. |
Disappointing List of Plugins | Barry Johns | AAX Plug-ins | 30 | 07-14-2012 04:29 AM |
Pro Tools 9 Bugs disappointing... | AUDIOSFX | macOS | 0 | 01-11-2011 06:04 PM |
Is It Just Me Or Is Strike Very Disappointing? | dmacintyre | Virtual Instruments | 2 | 03-14-2009 04:44 PM |
How Disappointing! | Hi-D-Ho-Man | Pro Tools M-Powered (Win) | 24 | 05-17-2005 08:19 AM |
6.1 mouse scrolling disappointing | ckevperry | Pro Tools TDM Systems (Mac) | 10 | 07-16-2003 11:04 PM |
