Old 10-26-2020, 11:17 AM
dunebuggy dunebuggy is offline
Default S4 knob section
Hi all,
Trying to get the knob section to switch to all.
Let say I choose "pan" I would like to have the associated knob section (8) all switching to pan mode.
Right now I'm using "focus " switch on the strip and after I choose the function to appear, works but slow.
I read that it works when the focus is not lit but I cannot "unlit" it.
Thanks guys, it's a great board but it's my 3 day on it and dont have xtra time than usual for the mix.
Eric
Old 10-26-2020, 12:34 PM
beanbagjimmy beanbagjimmy is offline
Default Re: S4 knob section
I too am wondering about this. Not much information to be found about this "Focus" button on the S4, which seems to be the "Swap" button on S6.
Ideally, when I press pan on the automation module, it would change all my tracks to display their individual pans, instead of having to cycle through individual track Focus'.
Would also love to get some info on the idea behind the Focus button in general.
Thanks so much!
BBJ
Old 10-26-2020, 01:27 PM
creativecontrol's Avatar
Greetings,
Focus determines which channel to target to toggle the function using the center array of switches on the Channelstrip module. Use the ALL switch from the Master Module (latches) then press a function switch on any Channelstrip module to change the function view for all strips.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 10-26-2020, 02:07 PM
Yes !
thank you
Looking to trade my skinny knob 408 for a skinny knob 402 audiobee System 5 0 04-06-2016 11:02 AM
Gain knob in dynamic section "goes to sleep" Will Russell ICON & C|24 1 01-28-2016 07:01 AM
How to get PT to loop a section, without having to listen to that entire section? FranHoop Pro Tools 9 3 11-04-2011 02:57 AM
002R Volume knob=Control24 Volume knob?? Gothboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-07-2010 04:04 PM
RECORDING SECTION BY SECTION jayrussell Tips & Tricks 3 04-28-2008 10:59 AM
