Old 01-31-2011, 04:48 PM
Anibal Anibal is offline
Default FYI love my SSD for System drive
I just installed an OWC 120 gig SSD drive on my 2nd optical bay with the System, very fast for restarts after crashes and very snappy for any other application opening, didn't sacrifice any of my drive bays... love it
PT 2018 HDX 1
Mac Pro Westmere 12 core 3.46 OSX 10.12.5
64 gig ram
Old 02-01-2011, 02:57 AM
RSSstudio RSSstudio is offline
Default Re: FYI love my SSD for System drive
curious - where did you keep your home folder? i heard it was best to keep it elsewhere then have an alias to not be writing to the SSD all the time.
i wanted to try this w/ my owc ssd but wasnt sure if pointing osx to a different homefolder on a different drive would mess up pt9.
thanks!
@bolooki
Old 02-01-2011, 08:08 AM
I just cloned my system drive, with everything in it...
lets see how it goes, I can always go back to the original...
PT 2018 HDX 1
64 gig ram
Old 02-01-2011, 11:18 AM
drenkrom drenkrom is offline
There isn't much reason to keep your home folder off the SSD, really. Yes, SSD's suffer from block rewrite penalties, even with the systems put in place in newer drives, but that will cause noticeable issues mainly on massive uninterrupted write operations, not the day-to-day document swapping and property-updating that normally occurs in the home folder. The drive's block reallocation systems will have loads of time to do their thing and you'll probably never notice a slowdown.
Unless you record audio or digitize video to your home folder (which you shouldn't be anyways), you can keep it on the SSD so all your file operations are infused with the essence of speed.
IHTH
Old 02-01-2011, 07:57 PM
edadema edadema is offline
Banned
I got the crucial 256 CT300 and it has active garbage clean up. Which is like TRIM but their version. I think everyone one is being to sensitive to the SSD drives stability.... I talked to Crucial and things have improved a lot. I have my Home folder on my drive and it seems fine...
Old 02-02-2011, 03:35 AM
Bill Denton Bill Denton is offline
IHTH
From what I have read, I believe the issue is not so much one of write speed as of the limited number of writes that can be performed...
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Old 02-02-2011, 04:24 AM
m4tune m4tune is offline
I tried SSD land, too.
My Corsair CSSD-F120GB2 has similar read/write speeds:
OWC: write-263Mb/s, read-271Mb/s
Corsair: write-256Mb/s, read-265Mb/s
I have no faster system starts or Pro Tools launch!!
10.5.8 on an USB drive takes exact the same time to boot:35sec
PT 8.03: 45sec
10.6.5 on internal SDD: System: 35 sec, Pro Tools 45sec!
Somehow disappointing…
Only exeption: PlugIns inside Pro Tools open much faster in PT9/10.6.5/SSD.
No idea if the reason for this is the ssd/OS/PT version.
Mac Pro 5,1 12 Core 3,46 GHz MacOs 10.15.7 (Catalina/Dosdude), 64GB Ram, Angelbird Wings x2, PT HDX, HD I/O, 2x 192i/o, 1x Digi Pre, 1x Red8Pre 2x Avid S1. Artist Transport, PT2021.6
http://www.4tune.at
Old 02-02-2011, 02:35 PM
Banned
Yes that is true but the SSD life expectance is still longer than a Platter Drive
Old 02-02-2011, 02:53 PM
Dism Dism is offline
Based on what, though?
All testing I've ever seen is based on "normal" use. Which is not a recording environment.
Cost vs. performance, I'm still not convinced. I'm gonna give it another year or so, probably.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 02-04-2011, 08:39 PM
Banned
To be honest I just got bored with my computer being so fast and still having a drive spinning at 7200. It wasn't a cost based analisist?
I love my Mix system starburst Pro Tools TDM Systems (Mac) 8 04-24-2010 06:03 PM
Question about adding some Apogee love to my system Premo Pro Tools TDM Systems (Mac) 25 09-14-2008 01:24 PM
Sl Much in Love wth my Procontrol system andre tchmil ProControl, Control|24, Command|8 0 09-13-2006 04:23 PM
OT: You know, I love my system... basschair 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-10-2003 12:25 AM
I fell in love at the DRIVE THRU!!!! nukmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 10-15-2002 11:32 AM
