Old 01-18-2011, 04:55 PM
Postman Postman is offline
Default Buffalo firewire drives crash Westmere
I bought 2 1.5 tbyte drives for sound effects storage a few months ago. They work great on my G5. Either of them cause an instant black curtain of death when attached to this new Westmere 6 core. It makes no difference if they are connected directly or through another drive. A quick google shows others are having the same problem.
Anyone here have trouble or a solution?
Old 01-18-2011, 06:45 PM
velvettone
Guest
Posts: n/a
Default Re: Buffalo FW800 drives crash Westmere
Which Oxford chipset does the drive use? Can you post a link to the drive specs?
Old 01-18-2011, 07:21 PM
I do not know which chipset, doesn't seem to be advertised. I only know they say it is compatible 10.4 and later.
http://www.buffalotech.com/files/products/HD-HSQ_DS.pdf
I have HD-HS1.5Q (or HD-HS1.5.TQ, same thing). When/if I hear back from Buffalo with news, I'll be back!
Old 01-18-2011, 08:09 PM
Craig F Craig F is offline
I don't think that Buffalo spends the money for Oxford chips
Thank you,
Craig
Old 01-19-2011, 07:30 AM
drenkrom drenkrom is offline
Do you have any other FW device plugged in when you try this? If so, try removing them to eliminate the possibility of a conflict on the FW buss.
If the problem persists, the next thing I'd try is to mount the drive on the G5 and reboot the G5 in FW Target mode (hold T while booting) and connecting it to your MacPro with a FW cable. The external drive should mount in target mode along with the internal drives of the G5. You can then run a disk check in Disk Utilities and/or a DiskWarrior on the drive from within the MacPro. It sound like the issue could be some header or directory weirdness.
Also, what partition map does the drive use?
IHTH
Old 01-19-2011, 07:47 AM
It appears to be a 64 bit incompatibility, I just discovered. A temporary fix is to boot Snow Leopard into 32 bit mode. (Hold 3 and 2 during boot until the apple logo appears or use a terminal command to change the default setting.) Older MacPro's boot into 32 bit mode by default, the newest models are set to boot into 64 bit mode by default.
Apple Partition Map. No other firewire devices, it does not matter which port is used.
I'm hoping to hear from Buffalo before the drives warranties expire in May.
Old 01-19-2011, 02:42 PM
bad jitter bad jitter is offline
Uh, I think Buffalos are the cheapest drives you can buy. I have avoided them for just that reason. Good luck!
Old 01-19-2011, 04:16 PM
sunburst79 sunburst79 is offline
Default Re: Buffalo firewire drives crash Westmere
When the warranty expires pull the HDD's out. Put them in OWC DIY enclosures and don't look back.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Yeah, well, I hoped they'd be good enough for sound effects storage (a master and a backup). I almost got away with it too, they've been working very well since last year. "Missed it by THAT much."
Old 01-19-2011, 04:17 PM
Good suggestion Hobo.
Buffalo (External)DriveStation Combo 4 Shefi Yishai Pro Tools TDM Systems (Mac) 0 05-12-2008 12:59 PM
External Firewire Drives crash protools everytime? jimmy buzzard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-10-2007 08:14 AM
Firewire Drives vs. ATA drives for Audio Playback and Recording Chence 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 04-26-2003 12:59 AM
ANDRE & TOM: Adaptec cards to copy from SCSI drives to Firewire drives with G4/HD? ragbor Pro Tools TDM Systems (Mac) 8 06-11-2002 08:08 AM
Avid Drives crash ATTO Drives!- Steve or anybody Raven Storage Subsystems 0 05-03-2001 04:05 AM
