I bought an MBOX 3 about 3 days ago and it has been nothing but a nightmare, the latest problem I am having is really weird driver issue. The MBOX runs fine as a sound card until you open pro tools and then it plays everything back in slow motion, in or out of Pro tools.
You have to re-install the drivers to get it back to normal and as soon as you open pro-tools your back to square one. I am literally loosing the plot and I am loosing faith in Avid's products, I had a saffire 24 before and it just worked, to be fair I never had these issues years ago with my mbox 1... Please help!! ![]() Pro tools Version 8.04 SiSoftware Sandra Computer Model : FUJITSU SIEMENS MS-7293 Workgroup : WORKGROUP Host Name : Danny-PC User : Danny Processor Model : Intel(R) Pentium(R) Dual CPU E2180 @ 2.00GHz Speed : 2GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Dual-Core Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 1MB, ECC, Synchronous, ATC, 4-way, 64 byte line size, 2 threads sharing Computer Mainboard : FUJITSU SIEMENS MS-7293 BIOS : Phoenix Technologies, LTD 6.00 PG 10/27/2006 Bus(es) : ISA X-Bus AGP PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 2GB DDR2 Chipset Model : 4358 0327h Front Side Bus Speed : 4x 200MHz (800MHz) Total Memory : 2GB DDR2 Channels : 1 Memory Bus Speed : 2x 267MHz (534MHz) Memory Module(s) Memory Module : 7F98 1G-UDIMM 1GB DIMM DDR2 PC2-4300U DDR2-534 (4-4-4-12 2-16-4-2) Memory Module : ITC 1GB DIMM DDR2 PC2-5300U DDR2-666 (5-5-5-15 3-20-5-3) Video System Video Adapter : NVIDIA GeForce 9500 GT (Microsoft Corporation - WDDM v1.1) (32 SM4.0 1.4GHz, 512MB DDR2 2x400MHz, PCIe 1.00 x16) Graphics Processor Storage Devices WDC WD200BB-00DGA0 200GB (ATA100, 2MB Cache) : 19GB (C:) SONY CD-RW CRX320EE (ATA33, DVD+-R, CD-RW, 2MB Cache) : 617MB (D:) NSVWVW 96N4TYJ (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R) : N/A (F:) Logical Storage Devices Hard Disk (C:) : 191GB (NTFS) @ WDC WD200BB-00DGA0 20GB (ATA100, 2MB Cache) 20100923_1229 (D:) : 617MB (CDFS) @ SONY CD-RW CRX320EE (ATA33, DVD+-R, CD-RW, 2MB Cache) Optical Drive (F:) : N/A @ NSVWVW 96N4TYJ (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R) Peripherals LPC Hub Controller 1 : 4358 3337h LPC Legacy Controller 1 : T0 88-68 Audio Device : 5218 3288h Audio Codec : 4332 0883h Serial Port(s) : 1 Disk Controller : 5218 5337h Disk Controller : 5218 0571h USB Controller 1 : 5218 3038h USB Controller 2 : 5218 3038h USB Controller 3 : 5218 3038h USB Controller 4 : 5218 3038h USB Controller 5 : 5218 3104h FireWire/1394 Controller 1 : 4358 3044h FireWire/1394 Controller 2 : 5218 3044h SMBus/i2c Controller 1 : VIA VT823x SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : VIA Rhine II Compatible Fast Ethernet Adapter Network Adapter : HTC Remote NDIS based Device (Ethernet, 426Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Home 6.01.7600 Platform Compliance : x86 Windows Experience Index Current System : 4.2 |
Where's your separate dedicated audio drive??? May or may not be related but it's still a necessity.
I have just bought a new one to replace my 40GB. It's not related and it's not a necessity I ran MBOX1 with PT 7.0 without any issues for years on a single disk..
![]() Quote:
As to your playback issue, it's possible some other audio application is locking the sample rate outside of PT. What other audio apps are you running? |
Hmmm, I'm not using anything but Windows media player to play some files. But if I close it inside or outside of PT I still get slow motion playback. I'm having a crack at installing PT and MBOX on my crappy XP SP3 laptop, because I am convinced it is a driver issue... But at the same time I hope it's not because I'm screwed and I will just have to take it back.
You need to make sure you have no other media apps running when you open PT to ensure that Pro Tools has exclusive use of the drivers.
![]() Quote:
I bought an M-Audio Firewire device that was a big pile of rubbish.. I had a saffire pro 14 and it was amazing compared to this pile of crap. If it was not for PT I would not touch Avid with your distant uncles barge pole.. |
Well I'm going to swop it for another MBOX tomorrow.. I so hope it works, I have pre-amps so I don't need the MBOX for that and when it was working right it sounded good.
Sounds like a plan. This is a new product so there's little sage wisdom yet.
Good luck- |
Right well I took it back to store, they called Avid and it turns out there is a problem with a small amount of the MBOX 3's where the internal clocking chip does not work as it should.
I should be recieving another one tomorrow hopefully :) |
mbox in slow motion when 48 khz or up | Cesar Cal | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-22-2011 03:58 PM |
Pro Tools -SLOW MOTION?! plz help | Valleyguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-20-2007 06:51 AM |
d24 go slow motion | ak47 | Pro Tools TDM Systems (Mac) | 4 | 07-02-2005 06:01 PM |
Slow Tempo/motion feature... | Musick | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-02-2005 02:33 AM |
slow motion !! | sandman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-19-2000 02:43 PM |
