After what appeared to be a successful C|8 firmware upgrade from 2.0.0 to 2.01.02, the Command|8 was not recoginized by Protools.
I have tried each of the following at least once: -reinstalling both firmware and driver from the latest download -reinstalling both firmware and driver from the PTLE 7.0 install disc -trashing Prefs -reinstalling the PTLE 7.3.1cs4 upgrade Nothing works. Protools peripherals does not show a Command|8 type, only "none," HUI," and "MotorMix." I tried selecting HUI then C|8 Surface, but that did not work. Also, I never got a "Found New Hardware" dialog from Windows, in case that is significant. No other HW or SW was installed at the same time of the upgrade, and before the upgrade, the C|8 was fine, except for the fader problems noted in the tech notes (the reason I tried to upgrade). What now? Thanks for any help. -David. Setup: Windows XP Pro SP2 Digi 002R Protools LE 4.3.1cs4 |
PT 8 Wont recognize COmmand 8 | cleverwon | ProControl, Control|24, Command|8 | 22 | 10-22-2010 04:51 PM |
TIP!!! : Do NOT upgrade your Command 8 's firmware or it might DIE like mine !!!! | painkilla72 | ProControl, Control|24, Command|8 | 10 | 11-08-2009 11:52 AM |
computer can not recognize the command 8 | atebo1218 | ProControl, Control|24, Command|8 | 0 | 03-21-2008 08:50 AM |
computer can not recognize the command 8 | atebo1218 | ProControl, Control|24, Command|8 | 0 | 03-21-2008 08:49 AM |
Command|8 Firmware 02.01.01 & Firmware Updater 1.4 | Avid | General Announcements | 0 | 06-08-2004 04:48 PM |
