Re: PT 2018.7 on MacOS 10.14 Mojave works for me
My specs are: -I'm on standard 2018.7 not ultimate -Yes I have a physical iLok I had since PT 10 -As of now I'm running on 256 buffer most of the time, since my iMac is a little low on power and has no separate video card, running a video with my session (almost always on ProRes Proxy) is taxing on the processor. But for my application 256 is more than enough. To any of you who work on Post or any project with video I HIGHLY recommend transcoding to Profes Proxy (if on mac), working with h.264 is even more taxing on the CPU. I use Compressor 4.4 to transcode from 30sec commercials to 90min movies, its very fast. -As of now I haven't sent multichannel through connect to the audio editor on RX7, but I'll report my findings with a couple of stereos and 5.1. I tested selecting multiple st or mono tracks and sending them through connect and no, it will only send the first track or stereo pair.. I think the multichannel deal on RX7 is meant for single multichannel tracks. It's still working great as of right now, still a little sad my Oxygen 49 is not recognized in PT but still most of my music is made on Logic and Reason, and no problems there. Also if any of you use Reason 10 with the rsTouch app from Delora it's also working great on iOS12 and Mojave Still any questions I can answer are welcome Cheers! Last edited by veinticinco; 09-25-2018 at 09:04 AM. |
I also have a physical iLok gen2 on a usb3 dock. For my case I did a fresh install, not an update (with the high sierra partition untouched). Also you may try and moving some plugins to a temporary folder and see if any of those are the issue. These are on Library>Application support> Avid> Audio> Plug-ins I have the Waves suite, RX6 and 7, and some of the Pro plugins from Avid and they are working fine.. Hopefully you can solve it |
As of now no 9093. EuControl has crashed a couple of times while bouncing, but start it back up and it keeps running.
Also another annoyance are the disappearing VCAs on the iPad app, but i just move one vac on top of the other in Edit view and they instantly appear, but that has been more an Avid issue than MacOS. I'll post any issue I have |
Mac Studio M1 Ultra 64GB macOS 13.2.1 Pro Tools 2023.3 Antelope Audio Discrete 8 SC |
I think the RX thing with multichannel is part of the Audiosuite bug - before 2018.7 I could send multiple mono channels and they'd show up in RX as stereo pairs, not it seems it only relates to track width. Fingers crossed Avid will repair that: I'd love to edit drums in RX as multitrack. If not, it means only Ultimate users can used the full features of RX7 Advanced, and that would be a shame...
#16
I ran into a problem with my artist control and eucon crashing. I found that I had to allow eucon in the privacy/accessibility system preferences and it stopped crashing. Maybe this will help someone else who may hit the same problem I had. I also have an issue with my eleven plugin asking for an I ilok license even though I’m on ultimate. The mkii version is fine. I’m guessing it’s not needed anymore.
#17
#18
It works! Thanks for the tip
Mac Pro 5,1 (Mid-2012) 12-core 2 x 3.3 GHz / MSI RX 560 / 40GB ram / macOS 10.14.5 / Pro Tools 2019.5 / Logic Pro X 10.4.4 Arturia Keylab 88 • Presonus Faderport 8 • MOTU 896 • iPad Air 2 w/ PT Control NI Komplete Ultimate 11 • Albion One • Soundiron Choirs • Pianoteq • Analog Lab • VSL SE/Chamber Strings • etc |
#19
#20
ProTools 2018.4 Ultimate and macOS Mojave | BillDog793 | Pro Tools 2018 | 121 | 03-07-2019 04:37 AM |
macOS 10.13.6 with 2018.4 | SigFriedChicken | macOS | 8 | 07-26-2018 02:39 AM |
macOS 10.14 Mojave and “cheese grater” Mac Pros | jsbach | Pro Tools 2018 | 37 | 06-17-2018 01:50 AM |
Weird UI glitches in 2018.3 on macOS 10.13.3 | Chingy | Pro Tools 2018 | 6 | 04-06-2018 05:17 AM |
Sluggish Zoom in/out + scrub issues 2018.1 (MacOS 10.13.3) | Hrmonik | Pro Tools 2018 | 0 | 01-28-2018 10:35 AM |
