S3Lx fader problem
Hi I m getting a message that fader are not working
On an S3 was happening on fader 11 then on fader 10 and 15 I did firmware upgrade but problem persist How is the procedure to send to avid to fix? I never did it Do i need to buy an asc and give a call first? Or there is a phone number to call? |
Re: S3Lx fader problem
Maybe its an obvious question but did you check the fader´s connector?
no i didn t have you have open it is it easy to check? is it one flat per fader?
I don't think you develop a problem with the connector, if you are running the latest Venue OS and you get fader problems then most likely you have a problem with these faders and they need replacement. You can always contact Venue support to find out your repair options
I sent it back to Avid to fix.
Just a question how it works do they swap the desk or fix that one as i had a pro forma price for the repair and was quite expensive thanks |
It all depends on the problem, sometimes it's just replacing one bad part, sometimes it's replacing the whole thing.
OSC issues on S3Lx | [email protected] | VENUE Live Sound Systems | 3 | 11-04-2016 07:08 AM |
S3LX & S6L I/O Sharing | jholmgren5 | VENUE Live Sound Systems | 3 | 07-22-2016 04:51 AM |
Protools 12.4 and S3LX | Mike496 | VENUE Live Sound Systems | 2 | 07-14-2016 10:19 AM |
S3LX USB playback audio not available on 2nd networked S3LX | megatracks | VENUE Live Sound Systems | 4 | 10-15-2015 06:29 AM |
10.3 and 10.3.1 Small Volume Fader AND Clip Gain Fader Problem | Ale | macOS | 1 | 10-11-2012 10:07 AM |
