Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | Control
Old 08-07-2017, 08:07 PM
Maple Green's Avatar
Maple Green Maple Green is offline
Default Command 8 dosn't work with other controllers!!
Hi there
I've recently purchased the "Command 8" controller, it works fine in my pro-tools 11.3.2 but as soon as I want to add another HUI controller like "Novation Zero SL MKII" , it doesn't works and pro tools give my this message:
" You Have selected a MIDI controller that is not compatible with command 8. please deselect this device or remove command 8 from your selection"
They just work fine alone but not along side each other
Is there a solution?
regards!
Old 08-07-2017, 08:15 PM
Default Re: Command 8 dosn't work with other controllers!!
[IMG][/IMG]
Old 08-08-2017, 01:45 PM
Tough to say(and I hope someone else has better news). when I had my DIGI003, I tried adding a Novation controller to work with plugins and it was a total disaster(the Novation piece went back to the store)
Asus x99, Intel i7 6800K, 32 gig DDR4, GeForce 750 Ti, HD/Native, HD IOx2, PT11HD, UAD Quad, preamps from Vintech, Five Fish Audio, Miktek, Focusrite, Chameleon Labs and Midas..............................
www.capricornsoundworks.com
Old 08-09-2017, 04:44 PM
Wizzoboy's Avatar
Wizzoboy Wizzoboy is offline
You can only use one HUI controller at a time.
Dell Precision 490 Workstation, dual 4 core 5355 Xeon, 16gb Samsung DDR2 ECC Ram - Windows 7 Ultimate 64bit - Nvidia GTX 650 GPU --3 x Internal WD Blacks - PT 2018.4 - Digi 002R - Mackie HUI - JBL Monitoring - Dell XPS 8700 with Win10 running Davinci Resolve 15.06b [
Old 08-12-2017, 10:57 PM
I was under the impression that the Command8 was not HUI when used with Pro Tools(I thought it used whatever protocol was used by 002/003 and neither of those uses HUI)?? As for multiple HUI devices, the peripherals menu has spots to configure 4 devices. That would seem to imply more than 1 can be used
Old 08-12-2017, 11:57 PM
Goobs's Avatar
Goobs Goobs is offline
For whatever it's worth, I use a Command|8 in tandem with a 003, and while the faders and transport controls are spread between the two units, as soon as you activate the Command|8, the plugin mapping functionality of the Command|8 ceases to function.
iMac (Retina 5K, 27-inch, Late 2015), 4.0 GHz Intel Core i7, 32 GB 1867 MHz DDR3, 500 GB Flash Storage SSD, macOS 10.12.6, Pro Tools|2018.4, Logic Pro X 10.4.1, WaveLab Pro 9.5, Waves Diamond, RX 6, Ozone 8, Neutron 2, Apogee Quartet, Eleven Rack, 003, Command|8, OWC Thunderbolt 2 Dual-Drive Dock, OWC Mercury Electra 480 GB 6G SSD, OWC Mercury Elite Pro 250 GB 7200 RPM HDD
Old 08-13-2017, 07:43 PM
Are you trying to use the Novation to control transport and plugins, or just want to use it to play midi and trigger VI plugins(like Minigrand, DB-33, EZdrummer, etc)? If it just the later, don't configure it under Peripherals at all. Set it up as a midi "instrument" under Setup>Midi>Midi Studio.
Old 08-13-2017, 09:18 PM
That's not true . this problem accrues only with Command 8
I've been using two HUI devices at the same time before purchasing the command 8
Old 08-13-2017, 09:20 PM
I was trying to use it with my "recording light" that is HUI type only
Is there another way to use "recording light" or Novation's transport functionality?
midi controllers dont work in PT 12 khaotic intent Pro Tools 12 5 02-05-2016 03:11 PM
Serious question, are there any MIDI controllers that actually work with PT 11? cdf2108 Pro Tools HDX & HD Native Systems (Mac) 8 08-28-2014 09:47 PM
d-Command and MC Transport / You cannot use EUCON with other Ethernet controllers wouters Artist Series 2 04-17-2014 01:28 PM
None of my artist series controllers work now trock Artist Series 4 11-18-2011 12:59 PM
recording on mbox dosn't work properly Kyle.R 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 10-06-2005 03:00 PM
